  4. Clutch
Clutch
67 Posts 7 Posters 27.0k Views 2 Watching
  • MightymanM Mightyman
    I replaced mine as I thought they were the cause of a problem I had. Turned out they were fine and didn't have any effect on it. But worth a try for you I suppose!
    RickyR
    RickyR
    Ricky
    @Mightyman definitely worth a try get all 3 for £20
    DT 125X
    • MightymanM
      Do you have a picture of your clutch basket handy, just to rule that out?
      RickyR 1 Reply Last reply
        RickyR
        RickyR
        Ricky
        @Mightyman i will have later when i strip it again
        DT 125X
          Push rods and ball bearing. Sounds far fetched to me
            RickyR
            RickyR
            Ricky
            @Calum I'm going to strip it soon get the ball and rod out to check them and do some more adjustment
            DT 125X
            • RickyR
              RickyR
              Ricky
              My ball had 2 flat sides so I've ordered a new 1
              DT 125X
              • MightymanM
                #55
                Wow, hopefully it's your fix man!
                • RickyR
                  RickyR
                  Ricky
                  Hopefully 0_1485622564300_20170128_165352.jpg 0_1485622590831_20170128_165418.jpg 0_1485622643466_20170128_165433.jpg 0_1485622674961_20170128_165500.jpg
                  DT 125X
                    NORFE used to chop up some M6 bolts and use as a bearing....
                    Not sayinf that's good practice but was good enough for him.
                    RickyR CalumC 2 Replies Last reply
                      RickyR
                      RickyR
                      Ricky
                      @Calum I've got some old bearings I was thinking of opening them up see if any are the same size the rods are ok
                      DT 125X
                        @Ricky That doesn't look great lol.
                        You can get the ball bearings off eBay for next to nothing..
                          RickyR
                          RickyR
                          Ricky
                          @Calum I've ordered 1 from yambits I was playing with the bearing idea as there can't be any difference surely
                          DT 125X
                            I should not have thought so, but as said the correct ball can be had off eBay.
                            • RickyR
                              RickyR
                              Ricky
                              Probably a daft question but with the bike off and my clutch pulled in should it freewheel or turn the engine over slightly when pushing it
                              DT 125X
                              • MightymanM
                                Very normal for it to turn the engine.
                                  RickyR
                                  RickyR
                                  Ricky
                                  @Mightyman so it wouldn't be normal if it didn't
                                  DT 125X
                                  • MightymanM
                                    Well in theory it shouldn't.. but I've found they always do.
                                      Yeb, cold oil is thicker and "sticks" more, so the clutch stil drags a bit.
                                      • B
                                        B
                                        Bananper
                                        Did you figure out the cause of this problem?
