  4. Clutch
Clutch
67 Posts 7 Posters 27.0k Views 2 Watching
  • RickyR Ricky
    @Mightyman these are the old 1s I changed it because it wasn't going in gear and sometimes it would get stuck in gear so when I'd pull up it wouldn't shift up or down until i turned the engine off then it would move easy
    @Ricky That's also consistent with a notched basket if I'm not mistaken.. Maybe your issue the whole time hasn't been the plates, but rather the basket. If the notches aren't too deep, try to file them down and see if it performs any better.
      It not going into gear could be a variety of things. Worn selector forks, bearings, clutch assembly, clutch springs.
      Sounds to me like the clutch isn't disengaging.
      Again what I said earlier will tell you it is clutch disengagement problem.
      Never heard of a worn basket on a dt before though. Maybe if it ran with no oil. My brother ran his dt gearbox on coolant and oil with no problems. So they are pretty well engineered.
      RickyR 1 Reply Last reply
        RickyR
        RickyR
        Ricky
        @Calum I took it to the local bike garage he said it sounds like 1 or both of push rods and ball I've had the bike on its side trying to get them out bit they don't want to come out so I'm going to get a magnet see if that works
        DT 125X
        • MightymanM
          I replaced mine as I thought they were the cause of a problem I had. Turned out they were fine and didn't have any effect on it. But worth a try for you I suppose!
          • MightymanM Mightyman
            RickyR
            RickyR
            Ricky
            @Mightyman definitely worth a try get all 3 for £20
            DT 125X
            • MightymanM
              Do you have a picture of your clutch basket handy, just to rule that out?
                RickyR
                RickyR
                Ricky
                @Mightyman i will have later when i strip it again
                DT 125X
                  Push rods and ball bearing. Sounds far fetched to me
                    RickyR
                    RickyR
                    Ricky
                    @Calum I'm going to strip it soon get the ball and rod out to check them and do some more adjustment
                    DT 125X
                    • RickyR
                      RickyR
                      Ricky
                      My ball had 2 flat sides so I've ordered a new 1
                      DT 125X
                      • MightymanM
                        #55
                        Wow, hopefully it's your fix man!
                        • RickyR
                          RickyR
                          Ricky
                          Hopefully 0_1485622564300_20170128_165352.jpg 0_1485622590831_20170128_165418.jpg 0_1485622643466_20170128_165433.jpg 0_1485622674961_20170128_165500.jpg
                          DT 125X
                            NORFE used to chop up some M6 bolts and use as a bearing....
                            Not sayinf that's good practice but was good enough for him.
                            RickyR CalumC 2 Replies Last reply
                              RickyR
                              RickyR
                              Ricky
                              @Calum I've got some old bearings I was thinking of opening them up see if any are the same size the rods are ok
                              DT 125X
                                @Ricky That doesn't look great lol.
                                You can get the ball bearings off eBay for next to nothing..
                                  RickyR
                                  RickyR
                                  Ricky
                                  @Calum I've ordered 1 from yambits I was playing with the bearing idea as there can't be any difference surely
                                  DT 125X
                                    I should not have thought so, but as said the correct ball can be had off eBay.
                                    • RickyR
                                      RickyR
                                      Ricky
                                      Probably a daft question but with the bike off and my clutch pulled in should it freewheel or turn the engine over slightly when pushing it
                                      DT 125X
                                      • MightymanM
                                        Very normal for it to turn the engine.
                                          RickyR
                                          RickyR
                                          Ricky
                                          @Mightyman so it wouldn't be normal if it didn't
                                          DT 125X
