  4. Clutch
Clutch
67 Posts 7 Posters 25.3k Views 2 Watching
  • MightymanM Mightyman
    It COULD have been triggered by you changing the gear oil.
    EDIT:
    Or possibly the old plates had already worn enough to somehow make the issue less prominent... Why did you change the clutch in the first place? Could you give the old bits a try just to confirm it's not the assembly that's incorrect?
    RickyR
    RickyR
    Ricky
    wrote on last edited by Ricky
    #44
    @Mightyman these are the old 1s I changed it because it wasn't going in gear and sometimes it would get stuck in gear so when I'd pull up it wouldn't shift up or down until i turned the engine off then it would move easy
    DT 125X
    MightymanM 1 Reply Last reply
    • RickyR Ricky
      @Ricky That's also consistent with a notched basket if I'm not mistaken.. Maybe your issue the whole time hasn't been the plates, but rather the basket. If the notches aren't too deep, try to file them down and see if it performs any better.
        It not going into gear could be a variety of things. Worn selector forks, bearings, clutch assembly, clutch springs.
        Sounds to me like the clutch isn't disengaging.
        Again what I said earlier will tell you it is clutch disengagement problem.
        Never heard of a worn basket on a dt before though. Maybe if it ran with no oil. My brother ran his dt gearbox on coolant and oil with no problems. So they are pretty well engineered.
        RickyR 1 Reply Last reply
          RickyR
          RickyR
          Ricky
          @Calum I took it to the local bike garage he said it sounds like 1 or both of push rods and ball I've had the bike on its side trying to get them out bit they don't want to come out so I'm going to get a magnet see if that works
          DT 125X
          • MightymanM
            I replaced mine as I thought they were the cause of a problem I had. Turned out they were fine and didn't have any effect on it. But worth a try for you I suppose!
              RickyR
              RickyR
              Ricky
              @Mightyman definitely worth a try get all 3 for £20
              DT 125X
              • MightymanM
                Do you have a picture of your clutch basket handy, just to rule that out?
                  RickyR
                  RickyR
                  Ricky
                  @Mightyman i will have later when i strip it again
                  DT 125X
                    Push rods and ball bearing. Sounds far fetched to me
                      RickyR
                      RickyR
                      Ricky
                      @Calum I'm going to strip it soon get the ball and rod out to check them and do some more adjustment
                      DT 125X
                      • RickyR
                        RickyR
                        Ricky
                        My ball had 2 flat sides so I've ordered a new 1
                        DT 125X
                        • MightymanM
                          #55
                          Wow, hopefully it's your fix man!
                          • RickyR
                            RickyR
                            Ricky
                            Hopefully 0_1485622564300_20170128_165352.jpg 0_1485622590831_20170128_165418.jpg 0_1485622643466_20170128_165433.jpg 0_1485622674961_20170128_165500.jpg
                            DT 125X
                              NORFE used to chop up some M6 bolts and use as a bearing....
                              Not sayinf that's good practice but was good enough for him.
                              RickyR CalumC 2 Replies Last reply
                                RickyR
                                RickyR
                                Ricky
                                @Calum I've got some old bearings I was thinking of opening them up see if any are the same size the rods are ok
                                DT 125X
                                  @Ricky That doesn't look great lol.
                                  You can get the ball bearings off eBay for next to nothing..
                                    RickyR
                                    RickyR
                                    Ricky
                                    @Calum I've ordered 1 from yambits I was playing with the bearing idea as there can't be any difference surely
                                    DT 125X
                                      I should not have thought so, but as said the correct ball can be had off eBay.
                                      • RickyR
                                        RickyR
                                        Ricky
                                        Probably a daft question but with the bike off and my clutch pulled in should it freewheel or turn the engine over slightly when pushing it
                                        DT 125X
                                        • MightymanM
                                          Very normal for it to turn the engine.
