DT200WR restoration project pic heavy
Jealous
me? Not much. (lying) well done, looks good, have picked up another bike as well but too much to do and filled up new shed/ workshop already. Need to sell dt250 1976 , never floated my boat tbh, or build another shed
@oldman you've got enough bikes already haha. Very good price this was.
If anyone has any spares let me know, the oil pump works and is in mint condition but I need the 2t tank and level sensor.
Here's some pics of the strip down today.
All bolts came out nicely without drilling any.There are the before the deep cleaning process pics.
The beast engine everyone wants for the 125r hha
Dropped the parts at the powdercoaters, swing arm and little bits and pieces are being done in an OEM silver. The frame is being done in 4006 purple... 93 yz style
The exhaust expansion is being sand blasted to have vht paint and the silencer will be Powder coated.
I'm taking the fairings to a specialist for some magic.... You'll see
Parts I've ordered:
Original graphics
OEM copy hand guards
Purple TLD grips
Polisport rear muflap
New odometer.
New UFO fork guards
HEL braided brake lines
Blue silicone hose kit
Pale blue seat cover and strap (yamaha)
New OEM clutch cable
Pro taper se red bars
New chain guide
New chain guard -
@Minia cheers mate... Stay tuned
Thanks. Took about 5 hrs with some cleaning in the process.. always careful to not round any bolts
The trick to make any project look good is attention to detail... including deep cleaning.
See how well these 25year old parts come up.
Here's the engine.. I am not painting the crankcases as they were bare from the factory,but I'll give a light polish before installing to frame.
Took ages to clean it to this standard.. especially around the sprocket, exhaust manifold and underneath..
I also sourced a 125re 2t bottle which I will use as I cannot find the original one.. the level sensor connector is the same, so hoping that will work. Also the oil pump is in good condition and the carburettor has the oil intake fitting. I will use clear hoses as always.
The side stand switch is missing but I have found the wires for it.. so I will fix this.
Radiators are in such good condition.. but these bikes do not have any braces to protect them unlike the 125
New fork guards came..
A decent camera probably doesn't hurt neither
With regards to the RE Oil Sender, uhh it's just a switch. It's either on or off, so shouldn't be hard to get working.
@Calum it's only a mobile haha
So some new bits came
Rear wheel before my gf spent 2hrs cleaning
After
This bearing was damaged so pressed it out.. just trying to source a new one
Also cleaned up the fuel tank and wiring loom OCD style.
Probably lost 1kilo of dirt and grease from the bike
After
@Louis-James The rear wheel looks totally transformed, top job by your misses. What products did she use to achieve those results???
@NINJA said in DT200WR restoration project pic heavy:
Mostly elbow grease haha, sprayed in multi purpose spray (wd40 type stuff) left over night then she used a tooth brush and scotch bright+ brake clean and hand polished
@Calum cheers dude. Yes and more to come... Hopefully tomorrow.
Only thing that might delay this project is that shock bearing + collars... Knowing how everyone always sends the wrong part
@Calum yes a few people but I will need to do a drawing.. they don't like doing free hand jobs and programming for a small quantity isn't what they want
