Coolant problem
I have a weird problem on my dt. The coolant is going back to the expansion bottle and it gets filled up and leaks out, and when i open the radiator and rev the bike it spits out water. Ive tried two heads, and swapped headgaskets. Changed the bearing with the water pump. What could cause this?
If it's going into the expan then it's leaking past the cap. Try a new cap 1.1 bar
@Louis-James yeah but it should not be that much pressure
@Bananper said in Coolant problem:
Your cylinder gasket surface might not be good, or your nuts not torqued enough
