  4. DT200WR restoration project pic heavy
272 Posts 17 Posters 156.9k Views 5 Watching
  • Louis-DT-WRL
    Louis-DT-WRL
    Some new bits came,
    Cleaned up the forks and front wheel and indeed the new fork guards.
    New swing arm chain guard, chain guide and mudflap installed.
    Fairings should be back from then bodywork shop next week.
    Handguards installed and controls cleaned up.
    • Louis-DT-WRL Louis-DT-WR
      Some new bits came,
      #73
      @Louis-James Nice job and boy that kickstand looks MAAAAAAAAAAAHHHHHHHHHHOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOSSSSSSSSSSIIIIIIIIIIIIIIIVVVVVVVVVVVVVEEEEEEEEEEEEEEEEE!!!!!!! :grinning_face_with_smiling_eyes: :smiling_face_with_open_mouth_closed_eyes: :grinning_face_with_smiling_eyes:
        Louis-DT-WRL
        Louis-DT-WRL
        @NINJA I know, strange hahaha but better than DT stand I think
          Louis-DT-WRL
          Louis-DT-WRL
          @Louis-James anyone know much about fitting a battery? I just want to do a lights and PV test.. I think you can connect it to the loom r/s of flywheel
            @Louis-James does it have the three white wires coming from the stator? You'd need them and a voltage regulator to convert the output from ac to dc.
            • D DTR+NSR
              Louis-DT-WRL
              Louis-DT-WRL
              @DTR-NSR I'll have another look but it has a voltage regulator already
                Louis-DT-WRL
                Louis-DT-WRL
                So hopefully the main part of the project will be done this week.
                Got the oil tank all set up nicely.
                I had to extend one of the coolant hoses as was way too short.
                This fairing bracket I ordered was no longer available so made one myself.
                As you can see the fuel tank is in amazing condition for age.. didn't even powdercoat it..
                All the colours are colliding and making a nice 90s mess haha just as I wanted.
                The fairings are ready to collect from the body shop
                  @Louis-James if its got the voltage reg already I should think it will. Probably have 3 white wires going to the vr and one red. The red is the 12v positive output that would go to the battery.
                  • Louis-DT-WRL
                    Louis-DT-WRL
                    We'll here we are.... Fairings and graphics.
                    • Louis-DT-WRL
                      Louis-DT-WRL
                        Yes mate, that's look the tits!
                          Louis-DT-WRL
                          Louis-DT-WRL
                          @Calum cheers Cal. Did you notice the paint has fibre pattern? Just waiting for the indicators before I can put headlight and rear fender on.. then sort the brakes and chain
                            @Louis-James She looks lovely dude, where did you get the heat shield stuff from???
                              Louis-DT-WRL
                              Louis-DT-WRL
                              @NINJA thanks:) you can get it in eBay, I got 6 fairly large sheets for £12
                                Yeah that's looking mega mate!
                                  @Louis-James Do you have a link please bud???
                                    Louis-DT-WRL
                                    Louis-DT-WRL
                                    @NINJA can't fit the exact listing but this is similar
                                    https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F130796418818
                                      #89
                                      @Louis-James OK Thanks, I ordered some from that dude before for my DTR, but the sheets were a bit on the small side. Good quality heat shield tho - nice and thick, I'll need some for my MX 125. 😉
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        Well this was annoying.. normally wemoto is good but they sent the wrong brake lines... Says on the box dt200wr 3xp.
                                        Will not fit. Even if routed differently.
                                        Thinking about 1990-96 yz250 lines now
                                        Got the calipers sand blasted and painted up.
                                        Finally the clutch cable came 🙂
                                        Only a few bits holding me up.
                                        New chain rollers came.
                                        • Louis-DT-WRL
                                          Louis-DT-WRL
                                          New horn
                                          New yz250 rear brake line
                                          New yz250 neon pink disc guard (matched shock spring)
                                          And the FMF fatty. Can't believe how much thicker the metal is to the DEP.
                                          Just the final bits and pieces need doing. Still waiting for the indicators and custom front brake hose.
