  3. Welcome New Owners!
  4. New guy GILERA SC125 help NEEDED
30 Posts 5 Posters 6.8k Views
    @gilerasc125 If the engine was scored badly it may have required an overbore.
    You really think the theives that stole my bike warmed it up before storming up the road on it. Yes it's not great for the engine, but they would withstand the punishment.
    So I would check to make sure the fueling hasn't been messed about with and the oil pump is not faulty. Check that the CDI is firing correctly, and not firing way too early.
    Also it's possible that the mileage is less than accurate, I.E. the speedo has spent a lot of time disconnected.
    MOT History check the vehicle to see if only a few miles pass year on year. That might indicate it's not been recorded accurately.
    I know my MOT for my DT says it's on 300 miles when in actuality it's done 20K
    gilerasc125G
    gilerasc125G
    gilerasc125
    @Calum thanks man. Where you based pal?
      gilerasc125G
      gilerasc125G
      gilerasc125
      @Calum ive fully Service history For this Bike confirming milage. Will put a video on it idling so people can get a Better idea
      • gilerasc125G gilerasc125
        @gilerasc125 West Midlands.
        Something is definitely amiss. I've seen people on here get like 20K out the original piston. Someone claimed they have 40'000Km out of the original top end on here.
        D declanD 2 Replies Last reply
          From experience it tends to be running too lean that kills two strokes. Though a 2 stroke makes more power the leaner it runs. At 57mm you often have to modify the power valve for clearance. And the head gasket will need opening up. When the barrel 1st seized they might have replaced it with a 'good' second hand barrel that had already been taken out a few sizes.
          gilerasc125G 1 Reply Last reply
          • D DTR+NSR
            gilerasc125G
            gilerasc125G
            gilerasc125
            @DTR-NSR ![alt text))
            Taken power valve out now was all full of carbon cleaned up nice. There is a groove thats been cut into it as in machined. Got all the pics but want let me post them. Luckily piston and rings are good. When i was removing pv it had been pinned in the wrong direction
              @gilerasc125 A how to upload pics guide - https://dt125r.co.uk/topic/5/embedding-images
                gilerasc125G
                gilerasc125G
                gilerasc125
                @NINJA thats like trying to speak mandarin 😂😂
                  @gilerasc125 Are you using your phone to access this forum??? As that will cause problems uploading pics. 😉
                    gilerasc125G
                    gilerasc125G
                    gilerasc125
                    @NINJA yes 😎
                    gilerasc125G NINJAN 2 Replies Last reply
                      @NINJA yes 😎
                      gilerasc125G
                      gilerasc125G
                      gilerasc125
                      @gilerasc125
                      The powervalve is meant to have to have two pins that help it stay together in the centre when you run the bolt threw. My pv hant got them pins 😂
                        @NINJA yes 😎
                        @gilerasc125 That's why you can't upload any pics, as the forums software is buggy with mobile devices. Using a PC of some form is the best way to access this friendly forum. 😉
                          @NINJA I rarely have issues with this forum from a mobile device. What browser are you using? I always use Firefox and can use all the features just fine.
                          You should be able to request a desktop version from your mobile.
                          The website is written in Bootstrap CSS, meaning that really its the same code for desktop and mobile. So any bug that exists would be present in both systems.
                            @Calum Good_to_know, others have reported issues when using mobiles etc. So I was just going on what they have experienced.
                              @Calum where exactly Calum I’m walsall
                                @declan I should know this. South West Rather.
                                where exactly, well if you must know 51°53′N 002°04′W
                                  #27
                                  @Calum I didn’t mean that exact lol yeah your quite far from me still
                                    @declan You did say exactly to be fair. If you didn't mean it then why did you say it.
                                    I'm messing. That isn't my exact location.
                                      @Calum didn’t think it was when you said West I thought you were closer than I thought oh well probably for the best bike thievery is everywhere this end in fact just 2 hrs ago an unmarked ran over a bike they were chasing
                                        @declan Bike theft is everywhere in the UK No Exceptions.
                                        The law needs to come down hard on it in my opinion. It's disgraceful
