  4. DT200WR restoration project pic heavy
272 Posts 17 Posters 158.0k Views 5 Watching
  • Louis-DT-WRL Louis-DT-WR
    Here's the spare set of wheels and tyres that came with the bike.
    Top brand tyres to be fair.
    The rear wheel is a straight swap (3bn hub with 2.15 alloy rim)
    However the front wheel has a different hub... Like the late 90s yz.
    If the brake discs faces offset is correct then I could turn the hub in a lathe to get the brake disc to fit,
    Not really sure what I want to do with these wheels. Part of me wants to build them up with purple hubs and stainless spokes.
    I'd probably sell the tyres as they are MX ones
    NottsbikerN
    NottsbikerN
    @Louis-James you tried DTX wheels in your WR? I'm going to run mine this year as-is and rebuild it next winter but would like to sumo it and use as a commuter.
    Bike looks great btw!
    Carriers are ten a penny in Thailand and South America 😉
    • Glynn123G
      Glynn123G
      Glynn123
      I've got a set of wr 200 wheels at home, front ones nice, back not so much but still usable, let me know if you're interested at all cause I'm not going back to nobbys anymore with my DT.
      • Glynn123G Glynn123
        Louis-DT-WRL
        Louis-DT-WRL
        @Glynn123 do you have a picture of the front wheel?
        Is the tire on it?
        Glynn123G 1 Reply Last reply
        • NottsbikerN Nottsbiker
          Louis-DT-WRL
          Louis-DT-WRL
          @Nottsbiker thanks mate. The only wheels I've put on my dt200wr are the original ones.
          I will probably sell both tyres and the front complete wheel
            Is the tire on it?
            Glynn123G
            Glynn123G
            Glynn123
            @Louis-James yeah there's some dualsport tyre on it right now, I'll try get a picture when I finish work in the morning, should get back to you sometime over the weekend if not though
              Louis-DT-WRL
              Louis-DT-WRL
              @Glynn123 ok thanks.
              Would you prefer to sell the whole set up? Or do you want the tyre?
                Glynn123G
                Glynn123G
                Glynn123
                @Louis-James I'd be happy to sell the whole lot if you wanted, I have no use for the tyre as my DT is just in sm trim and should be staying that way
                  Louis-DT-WRL
                  Louis-DT-WRL
                  @Glynn123 did you fit wr200 forks?
                  Just after the front wheel tbh.
                  Thanks
                    Thanks
                    Glynn123G
                    Glynn123G
                    Glynn123
                    wrote on last edited by Glynn123
                    #165
                    @Louis-James I fit WR 426 forks but made my own custom axle to run the standard DTR/WR200 front hub sizes, the WR200 front disc was the same size as a standard nissin front brake system on a WR 426 so was a better wheel choice than changing calipers to use the smaller DTR wheel and disc combo
                      Louis-DT-WRL
                      Louis-DT-WRL
                      @Glynn123 great thanks
                        Louis-DT-WRL
                        Louis-DT-WRL
                        @Glynn123 the front wheel I have looks exactly like a wr400 or wr426.
                          Glynn123G
                          Glynn123G
                          Glynn123
                          @Louis-James the axle is larger in the 400/426, the WR 200 wheels I bought use the same size axle as a DT, I actually ran them with the DT spacers on my standard forks for a while. Is this the same with yours?
                          Louis-DT-WRL NottsbikerN 2 Replies Last reply
                            Louis-DT-WRL
                            Louis-DT-WRL
                            @Glynn123 I haven't tried them on yet. But you could use bearings with small ID?
                              NottsbikerN
                              NottsbikerN
                              @Glynn123 according to the All Ball's site the 400 front end fits straight onto the 200. Guessing it wasn't as easy as that for the 125?
                                Glynn123G
                                Glynn123G
                                Glynn123
                                @Nottsbiker are you referring to the front wheel or fork assembly mate?
                                • NottsbikerN
                                  NottsbikerN
                                  Sorry - meant to say the 400 front end complete - yokes / forks etc
                                    Glynn123G
                                    Glynn123G
                                    Glynn123
                                    #173
                                    @Nottsbiker the yokes use a different bearing type on the top, and bottoms different taper too. Standard DT 125 uses ball bearings on the top compared to tapered rollers, also 400 stem is longer, takes some spacer work and a bearing cup but the swaps doable if you have a lathe.
                                      NottsbikerN
                                      NottsbikerN
                                      @Glynn123 thanks. Makes me realise I'll be building supermoto rims onto my hubs and looking for an oversized disk to make the changes. I have access to cnc etc but will try to minimise this type of work to just a caliper bracket
                                        NottsbikerN
                                        NottsbikerN
                                        @Louis-James few quick questions if you don't mind;
                                        Front fork guards - assuming you've gone with UFO YZ new old stock?
                                        What size is the bottom bolt on the forks that hold them together? It's massive and I need to buy the correct one
                                        Is the chainguard the same as a 125?
                                        Is the gear lever the same as a 125?
                                        Where did you get your chain slider without taking out a new mortgage?
                                        I've got a factory manual in Japanese but no parts list - do you have one at all you could email across?
                                        Cheers - Ben
                                          Cheers - Ben
                                          Louis-DT-WRL
                                          Louis-DT-WRL
                                          @Nottsbiker said in DT200WR restoration project pic heavy:
                                          Cheers - Ben
                                          Hi Ben,
                                          Yes the fork guards are old stock yz ones around £28
                                          On the forks, are you regarding the one under the bottom of the fork leg?
                                          I used a cheap AliExpress chain guard for the dt125r
                                          The gear lever is the same.
                                          The chain slide I bit the bullet and bought one from Yamaha... £45
