  4. DT200WR restoration project pic heavy
272 Posts 17 Posters 147.5k Views 5 Watching
  • Glynn123G Glynn123
    I've got a set of wr 200 wheels at home, front ones nice, back not so much but still usable, let me know if you're interested at all cause I'm not going back to nobbys anymore with my DT.
    Louis-DT-WRL Offline
    @Glynn123 do you have a picture of the front wheel?
    Is the tire on it?
    Glynn123G 1 Reply Last reply
    • NottsbikerN Nottsbiker
      @Louis-James you tried DTX wheels in your WR? I'm going to run mine this year as-is and rebuild it next winter but would like to sumo it and use as a commuter.
      Bike looks great btw!
      Carriers are ten a penny in Thailand and South America 😉
      @Nottsbiker thanks mate. The only wheels I've put on my dt200wr are the original ones.
      I will probably sell both tyres and the front complete wheel
      • Louis-DT-WRL Louis-DT-WR
        Is the tire on it?
        Glynn123G Offline
        Glynn123G Offline
        Glynn123
        @Louis-James yeah there's some dualsport tyre on it right now, I'll try get a picture when I finish work in the morning, should get back to you sometime over the weekend if not though
          @Glynn123 ok thanks.
          Would you prefer to sell the whole set up? Or do you want the tyre?
            Glynn123G Offline
            Glynn123G Offline
            Glynn123
            @Louis-James I'd be happy to sell the whole lot if you wanted, I have no use for the tyre as my DT is just in sm trim and should be staying that way
              @Glynn123 did you fit wr200 forks?
              Just after the front wheel tbh.
              Thanks
                Thanks
                Glynn123G Offline
                Glynn123G Offline
                Glynn123
                wrote on last edited by Glynn123
                #165
                @Louis-James I fit WR 426 forks but made my own custom axle to run the standard DTR/WR200 front hub sizes, the WR200 front disc was the same size as a standard nissin front brake system on a WR 426 so was a better wheel choice than changing calipers to use the smaller DTR wheel and disc combo
                  @Glynn123 great thanks
                    @Glynn123 the front wheel I have looks exactly like a wr400 or wr426.
                      Glynn123G Offline
                      Glynn123G Offline
                      Glynn123
                      @Louis-James the axle is larger in the 400/426, the WR 200 wheels I bought use the same size axle as a DT, I actually ran them with the DT spacers on my standard forks for a while. Is this the same with yours?
                      Louis-DT-WRL NottsbikerN 2 Replies Last reply
                        @Glynn123 I haven't tried them on yet. But you could use bearings with small ID?
                          NottsbikerN Offline
                          NottsbikerN Offline
                          @Glynn123 according to the All Ball's site the 400 front end fits straight onto the 200. Guessing it wasn't as easy as that for the 125?
                            Glynn123G Offline
                            Glynn123G Offline
                            Glynn123
                            @Nottsbiker are you referring to the front wheel or fork assembly mate?
                            • NottsbikerN Offline
                              NottsbikerN Offline
                              Sorry - meant to say the 400 front end complete - yokes / forks etc
                                Glynn123G Offline
                                Glynn123G Offline
                                Glynn123
                                #173
                                @Nottsbiker the yokes use a different bearing type on the top, and bottoms different taper too. Standard DT 125 uses ball bearings on the top compared to tapered rollers, also 400 stem is longer, takes some spacer work and a bearing cup but the swaps doable if you have a lathe.
                                  NottsbikerN Offline
                                  NottsbikerN Offline
                                  @Glynn123 thanks. Makes me realise I'll be building supermoto rims onto my hubs and looking for an oversized disk to make the changes. I have access to cnc etc but will try to minimise this type of work to just a caliper bracket
                                    NottsbikerN Offline
                                    NottsbikerN Offline
                                    @Louis-James few quick questions if you don't mind;
                                    Front fork guards - assuming you've gone with UFO YZ new old stock?
                                    What size is the bottom bolt on the forks that hold them together? It's massive and I need to buy the correct one
                                    Is the chainguard the same as a 125?
                                    Is the gear lever the same as a 125?
                                    Where did you get your chain slider without taking out a new mortgage?
                                    I've got a factory manual in Japanese but no parts list - do you have one at all you could email across?
                                    Cheers - Ben
                                      Cheers - Ben
                                      @Nottsbiker said in DT200WR restoration project pic heavy:
                                      Cheers - Ben
                                      Hi Ben,
                                      Yes the fork guards are old stock yz ones around £28
                                      On the forks, are you regarding the one under the bottom of the fork leg?
                                      I used a cheap AliExpress chain guard for the dt125r
                                      The gear lever is the same.
                                      The chain slide I bit the bullet and bought one from Yamaha... £45
                                        Cheers - Ben
                                        Hi Ben,
                                        NottsbikerN Offline
                                        NottsbikerN Offline
                                        @Louis-James nice one mate
                                        Did your fork guards come with the clamp / guide parts? Mine are yellow and broken
                                        The fork bolt is the bottom one as I need to fit some new seals as mine are leaking. They've taken out the pads too ffs!
                                        Ben
                                          Ben
                                          @Nottsbiker yes they came with the clamps.
                                          I don't think it's a standard size bolt but it's probably the copper washer leaking.
