  4. DT200WR restoration project pic heavy
272 Posts 17 Posters 162.9k Views 5 Watching
  • Louis-DT-WRL Louis-DT-WR
    @NINJA cheers 🙂
    Can anyone help find me an original wr200 or dt200wr luggage rack.
    I can't find it on the diagrams but many of them seem to have them from factory.
    Part number?
    Maybe only certain countries had them.
    @Louis-James Is that the original one which came with the bike? If so why not just get it re-powder coated???
      Louis-DT-WRL
      Louis-DT-WRL
      @NINJA it's not mine.. just a picture I found online
        @Louis-James AAAHHHH OK - shame but I'm sure that you'll find one from somewhere??? 😉
          wrote on last edited by Darty
          #155
          Complete the look. Full 90s.
          https://www.ebay.co.uk/itm/VINTAGE-MENS-90S-SKI-SNOWBOARD-JACKET-PULLOVER-SIZE-XL-A2823/382737063987?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20140122125356%26meid%3Ddd4268f2322b4c7bac0d6581a0049273%26pid%3D100005%26rk%3D1%26rkt%3D12%26sd%3D392217898710%26itm%3D382737063987&_trksid=p2047675.c100005.m1851
          • Louis-DT-WRL
            Louis-DT-WRL
            Here's the spare set of wheels and tyres that came with the bike.
            Top brand tyres to be fair.
            The rear wheel is a straight swap (3bn hub with 2.15 alloy rim)
            However the front wheel has a different hub... Like the late 90s yz.
            If the brake discs faces offset is correct then I could turn the hub in a lathe to get the brake disc to fit,
            Not really sure what I want to do with these wheels. Part of me wants to build them up with purple hubs and stainless spokes.
            I'd probably sell the tyres as they are MX ones
              NottsbikerN
              NottsbikerN
              @Louis-James you tried DTX wheels in your WR? I'm going to run mine this year as-is and rebuild it next winter but would like to sumo it and use as a commuter.
              Bike looks great btw!
              Carriers are ten a penny in Thailand and South America 😉
              • Glynn123G
                Glynn123G
                Glynn123
                I've got a set of wr 200 wheels at home, front ones nice, back not so much but still usable, let me know if you're interested at all cause I'm not going back to nobbys anymore with my DT.
                • Glynn123G Glynn123
                  Louis-DT-WRL
                  Louis-DT-WRL
                  @Glynn123 do you have a picture of the front wheel?
                  Is the tire on it?
                  Glynn123G 1 Reply Last reply
                  • NottsbikerN Nottsbiker
                    Louis-DT-WRL
                    Louis-DT-WRL
                    @Nottsbiker thanks mate. The only wheels I've put on my dt200wr are the original ones.
                    I will probably sell both tyres and the front complete wheel
                      Is the tire on it?
                      Glynn123G
                      Glynn123G
                      Glynn123
                      @Louis-James yeah there's some dualsport tyre on it right now, I'll try get a picture when I finish work in the morning, should get back to you sometime over the weekend if not though
                        Louis-DT-WRL
                        Louis-DT-WRL
                        @Glynn123 ok thanks.
                        Would you prefer to sell the whole set up? Or do you want the tyre?
                          Glynn123G
                          Glynn123G
                          Glynn123
                          @Louis-James I'd be happy to sell the whole lot if you wanted, I have no use for the tyre as my DT is just in sm trim and should be staying that way
                            Louis-DT-WRL
                            Louis-DT-WRL
                            @Glynn123 did you fit wr200 forks?
                            Just after the front wheel tbh.
                            Thanks
                              Thanks
                              Glynn123G
                              Glynn123G
                              Glynn123
                              wrote on last edited by Glynn123
                              #165
                              @Louis-James I fit WR 426 forks but made my own custom axle to run the standard DTR/WR200 front hub sizes, the WR200 front disc was the same size as a standard nissin front brake system on a WR 426 so was a better wheel choice than changing calipers to use the smaller DTR wheel and disc combo
                                Louis-DT-WRL
                                Louis-DT-WRL
                                @Glynn123 great thanks
                                  Louis-DT-WRL
                                  Louis-DT-WRL
                                  @Glynn123 the front wheel I have looks exactly like a wr400 or wr426.
                                    Glynn123G
                                    Glynn123G
                                    Glynn123
                                    @Louis-James the axle is larger in the 400/426, the WR 200 wheels I bought use the same size axle as a DT, I actually ran them with the DT spacers on my standard forks for a while. Is this the same with yours?
                                    Louis-DT-WRL NottsbikerN 2 Replies Last reply
                                      Louis-DT-WRL
                                      Louis-DT-WRL
                                      @Glynn123 I haven't tried them on yet. But you could use bearings with small ID?
                                        NottsbikerN
                                        NottsbikerN
                                        @Glynn123 according to the All Ball's site the 400 front end fits straight onto the 200. Guessing it wasn't as easy as that for the 125?
                                          Glynn123G
                                          Glynn123G
                                          Glynn123
                                          @Nottsbiker are you referring to the front wheel or fork assembly mate?
