CRANK BEARINGS !!!
Simply bearings, yeah the DT uses an odd sized bearing. They're expensive as well! IIRC they're overrated bearings meant to handle more power, hence their reliability.
If you're uncertain, then grab them from PJME. Those guys know their shit and will sort you out.
@calum ah great thanks man really appreciated
i know this is old but did you find the right bearing number as think they might be this 6305r1sh29tcs35 but only got this nuumber from listing on ebay and maybe sombody that has changed them can say if they the right ones if so will work out a lot cheaper if they the right ones but they are the one pictured
i have a set my self just thought i would post up to see if the numbers matched i have searched the web and only found forgein page relaing to dtr but could not read it
looking on the this website http://www.athenaparts.com/eng/models/view/4453-section-25/yamaha-dt-125-r-re-x it looks like they may be the size with out measuring a set of bearings it hard to say but if they are the right ones will save people some money or maybe i will order two and see if they will measure up to the spare engine i have in shed as did not keep the olds
Main Bearing MS250620160YYK Bearing 6305ri - Koyo
Dimensions 62.00x25.00x16.00 -
fowlers part number is 93306-30556 and on this page it shows this part number 3rd one down just joined up
http://www.athenaparts.com/eng/products/view/4827/bearing-6305ri-koyo
so might be worth ordering a set to see if they match up but looks promising -
@DTR-NSR yes they are narrower. Found out the hard way years ago when I couldn't get my cases back together......
