  4. Leak near front axle?
14 Posts 5 Posters 1.9k Views
  • A
    A
    AndyJay
    I've had my new 01 DT R sat in my garage for a couple of weeks now and I've noticed a wet patch on the floor near the front axle at the left hand side. It's definitely not from the calliper, is there anything in that vicinity that could leak?
    • A AndyJay
      @AndyJay It could possibly be fork oil if one of the fork seals has perished???
      declanD A 2 Replies Last reply
        @NINJA +1
          Coolant hose hasn't split, or radiator not leaking.
            @NINJA +1
            @declan Are you trying to be my +1 now??? :grinning_face_with_smiling_eyes: :smiling_face_with_open_mouth_closed_eyes: :smiling_face_with_open_mouth_cold_sweat: :face_with_tears_of_joy: 🤣
              @NINJA 💯
                A
                A
                AndyJay
                @NINJA Had a gander earlier and that's exactly it. Not surprised really with it having been stood for so long.
                NINJAN NottsbikerN 2 Replies Last reply
                • A AndyJay
                  @AndyJay Well now you know which work you have to do my friend. 😉
                  • A AndyJay
                    NottsbikerN
                    NottsbikerN
                    @AndyJay easy job on the old DT 😉
                    • A
                      A
                      AndyJay
                      Should be a doddle.
                      What's the best brand of fork oil to go for?
                      • A AndyJay
                        Should be a doddle.
                        @AndyJay I have always found Silkolene oils to be top quality. Plus they have a large range of different weight oils to choose from;
                        https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2505460.m570.l1313.TR1.TRC0.A0.H0.XSilkolene+fork+oil.TRS0&_nkw=Silkolene+fork+oil&_sacat=0
                        A 1 Reply Last reply
                          A
                          A
                          AndyJay
                          @NINJA that's what I was looking at. What weight would you go for with the standard forks? I've been told I might be best off mixing 10 and 15 50/50 to get the best result.
                          • A AndyJay
                            @AndyJay It all depends on which sort of riding you do and how you like your forks to feel? Some riders like a softer springier feel with more compression to soak up the bumps more. While others like a stiffer feel for better cornering on tarmac. Adjusting the oil weight will only increase or decrease the time it takes for the oil to be pushed through the valves in the forks, thus giving a faster or slower compression. Search the web for some guides, but its a personal thing and ultimately something you will need to experiment with until you find your perfect set-up.
                            Swapping the springs out for some progressive ones will also make the forks much better too. But again it's all down to personal taste, rider weight, riding styles etc. and what works for one rider may not work for another. I would just put a 15W in and go from there, as a small jump from 10-15W would not be extremely noticeable, as say a jump from 10-30W would be much more noticeable.
                            • A AndyJay
                              NottsbikerN
                              NottsbikerN
                              @AndyJay that would give you a 12.5 weight - I'd stick with stock unless the springs are too bouncy for you and some stiffer springs if you're larger than an average rider
