  3. Questions i would like to ask DTR Related
16 Posts 6 Posters 2.0k Views
  • Walney-ReptilesW Offline
    Walney-Reptiles
    Hiya folks
    okay so i would like to ask the following questions...
    I have seen the list of crank case bearing codes on here that lists intotal of 5 bearings (I would like a full list for every bearing/roller bearing thats in the DTR engine) - im wanting to replace every single one on my dtr
    second question after doing a serch on here i cant find a list of the Oilseal numbers (id like to replace every single one on my dtr) - please could someone sort a list out?
    many thanks Josh
      https://dt125r.co.uk/topic/14/gearbox-bearings
      Litterally just search
        Walney-Reptiles
        @Calum Thanks callum but i have already seen this, and it dose not list all the bearings inside the engine Roller bearings etc...
          @Walney-Reptiles that's the only bearings I have used to build my engines with... You on about the gear linkage arm bearing? Never needed to replace that myself. It's not load bearing
          Seals I got from pjme
            Walney-Reptiles
            @Calum Im on about the needle roller bearing that sits at the end of the Clutch shaft (IKO TR152512 E03) Cant find on anywhere also my clutch arm bearing the smaller of the needle roller bearings is full of sand and id like to replace that, if i can find one
            • GoProKid95G Offline
              GoProKid95G Offline
              GoProKid95
              wrote on last edited by GoProKid95
              Hi mate, I can't remember the bearing numbers off the top of my head however, if they're available I'd certainly recommend
              https://www.123bearing.co.uk/
              The main bearings found in DT engines are a non-standard size (Thanks Yamaha) I believe the standard size is 17mm wide, whereas Yamaha main crank bearings are 16mm wide. In theory you can run the wider ones but I'd recommend if the ones coming out are original then use the numbers stamped on the outer race!
              Hope this helps! 🙂
              Any questions drop us a line! 😄
              GoProKid95
              2006 DT125RE - SM Conversion
                GoProKid95G Offline
                GoProKid95
                Okay, so I've done some digging, the main bearings for my bike (2006 DT125RE) was this
                https://www.123bearing.co.uk/bearing-6305R1-KOYO.php
                a Koyo 6305R1.
                The bearing from 123 is super super cheap. You can pay nearly £40 for a pair from Yambits. 😮
                GoProKid95
                • GoProKid95G GoProKid95
                  a Koyo 6305R1.
                  Walney-Reptiles
                  @GoProKid95 Cheers matey, i have ordered all the bearings i need, i found the Roller bearing on PJME and the rest i ordered of simply bearings, just gotta wait a month before i can buy the crank bearings and all the oil seals and a full gaskit kits, its gunna take a while as im out of work atm...
                    Walney-Reptiles
                    Okay another question,
                    Dose anyone on here do Wheel Rebuilds? or know anybody that dose? close to (ulverston Area) im looking to get mine rebuilt with heavy duty stainless steel spokes.
                    O NINJAN 2 Replies Last reply
                      O Offline
                      O Offline
                      @Walney-Reptiles had last ones done at central wheels with stainless spokes, first set done in basingstoke and took months and then fitted standard spokes, not what I wanted. Central were OK and did get small discount from bike show. Will probably send next set there as no one near me can do what I want in a reasonable time
                        NINJAN Offline
                        NINJAN Offline
                        @Walney-Reptiles Contact Paul Ritson @ https://www.facebook.com/sfxwheels/?ref=br_rs
                          Walney-Reptiles
                          @NINJA thanks Ninja i would contact but i dont have or use facebook can you get an email address i can contact him on?
                            NINJAN Offline
                            NINJAN Offline
                            @Walney-Reptiles Details here;
                            http://www.sfxwheels.moonfruit.com/
                            • M Offline
                              M Offline
                              mhbikesnbits
                              The go to place for wheels and I mean you will not get a better job is sids wheels can post em in if you choose but he is honestly top notch
                              • M mhbikesnbits
                                Walney-Reptiles
                                @mhbikesnbits cheers mate where is he located and have you had wheels done before as i could do with a rough price
                                M 1 Reply Last reply
                                  M Offline
                                  M Offline
                                  mhbikesnbits
                                  @Walney-Reptiles Stafford he’s based just google it cost me £60 for a set spokes supplied
