  3. Questions i would like to ask DTR Related
16 Posts 6 Posters 2.5k Views
    https://dt125r.co.uk/topic/14/gearbox-bearings
    Litterally just search
      Walney-ReptilesW
      Walney-ReptilesW
      Walney-Reptiles
      @Calum Thanks callum but i have already seen this, and it dose not list all the bearings inside the engine Roller bearings etc...
        @Walney-Reptiles that's the only bearings I have used to build my engines with... You on about the gear linkage arm bearing? Never needed to replace that myself. It's not load bearing
        Seals I got from pjme
          Walney-ReptilesW
          Walney-ReptilesW
          Walney-Reptiles
          @Calum Im on about the needle roller bearing that sits at the end of the Clutch shaft (IKO TR152512 E03) Cant find on anywhere also my clutch arm bearing the smaller of the needle roller bearings is full of sand and id like to replace that, if i can find one
          • GoProKid95G
            GoProKid95G
            GoProKid95
            wrote on last edited by GoProKid95
            Hi mate, I can't remember the bearing numbers off the top of my head however, if they're available I'd certainly recommend
            https://www.123bearing.co.uk/
            The main bearings found in DT engines are a non-standard size (Thanks Yamaha) I believe the standard size is 17mm wide, whereas Yamaha main crank bearings are 16mm wide. In theory you can run the wider ones but I'd recommend if the ones coming out are original then use the numbers stamped on the outer race!
            Hope this helps! ๐Ÿ™‚
            Any questions drop us a line! ๐Ÿ˜„
            GoProKid95
            2006 DT125RE - SM Conversion
            • GoProKid95G
              GoProKid95G
              GoProKid95
              Okay, so I've done some digging, the main bearings for my bike (2006 DT125RE) was this
              https://www.123bearing.co.uk/bearing-6305R1-KOYO.php
              a Koyo 6305R1.
              The bearing from 123 is super super cheap. You can pay nearly ยฃ40 for a pair from Yambits. ๐Ÿ˜ฎ
              GoProKid95
              • GoProKid95G GoProKid95
                a Koyo 6305R1.
                Walney-ReptilesW
                Walney-ReptilesW
                Walney-Reptiles
                @GoProKid95 Cheers matey, i have ordered all the bearings i need, i found the Roller bearing on PJME and the rest i ordered of simply bearings, just gotta wait a month before i can buy the crank bearings and all the oil seals and a full gaskit kits, its gunna take a while as im out of work atm...
                • Walney-ReptilesW
                  Walney-ReptilesW
                  Walney-Reptiles
                  Okay another question,
                  Dose anyone on here do Wheel Rebuilds? or know anybody that dose? close to (ulverston Area) im looking to get mine rebuilt with heavy duty stainless steel spokes.
                  O NINJAN 2 Replies Last reply
                    @Walney-Reptiles had last ones done at central wheels with stainless spokes, first set done in basingstoke and took months and then fitted standard spokes, not what I wanted. Central were OK and did get small discount from bike show. Will probably send next set there as no one near me can do what I want in a reasonable time
                      @Walney-Reptiles Contact Paul Ritson @ https://www.facebook.com/sfxwheels/?ref=br_rs
                        Walney-ReptilesW
                        Walney-ReptilesW
                        Walney-Reptiles
                        @NINJA thanks Ninja i would contact but i dont have or use facebook can you get an email address i can contact him on?
                          @Walney-Reptiles Details here;
                          http://www.sfxwheels.moonfruit.com/
                          • M
                            M
                            mhbikesnbits
                            The go to place for wheels and I mean you will not get a better job is sids wheels can post em in if you choose but he is honestly top notch
                            • M mhbikesnbits
                              Walney-ReptilesW
                              Walney-ReptilesW
                              Walney-Reptiles
                              @mhbikesnbits cheers mate where is he located and have you had wheels done before as i could do with a rough price
                              M 1 Reply Last reply
                                M
                                M
                                mhbikesnbits
                                @Walney-Reptiles Stafford heโ€™s based just google it cost me ยฃ60 for a set spokes supplied
