Why doesn't my DT125 get a spark?
A bit of a long story for a simple ending but yea.
So a few days back I was messing with the YPVS and getting it setup since it was making the bike really slow as the valve was pretty much closed. So I got it sorted out but it wasnt completely in tune so I tuned it more and got it all good and did a few wheelies until my idle revs started rising very much.
At that point I thought that my throttle cable got stuck or something and sorted that out as well. Didn't help anything. After that I took the carburetor out, cleaned the jets and tuned the fuel level just a bit. Then I put everything together and tried to start it and nothing. Then I thought that the spark plug must have gotten wet or something.
I took the plug out and dried it up. After that I tested if it gets a spark with the plug out of the head and when I turned the main switch on I got an electric shock which startled me a bit. But when i tried to kick start the bike to see if it got a spark, nothing. Nothing at all. I tried another spark plug and nothing.So what could be the issue? I think it could be either the stator or the cdi. Not sure yet.
Common issues on these bikes tend to be, side stand switch, neutral switch and kill switch. Make sure those are good.
Check the ignition barrel connector block, you may have disturbed it when faffing about.
Easiest way to sort the power valve out is to take the exhaust off and line the valve up with the port directly.
@Calum I could open up the kill switch and see if that is working correctly. I doubt that the main switch or the side stand switch have something wrong with them since the rear light turns on when I flip the power on and I don't have a side stand switch actually
@claws Iridium plugs tend to have a shorter lifespan over regular plugs. Mainly due to the stronger spark they produce. I used Iridium plugs in my DTR and noticed a definite drop in performance after a month's use. As plugs are as cheap_as_chips they are an easy component to replace. ;)
@claws The iridium plugs are cheaper on ebay, especially if you buy 4 at a time like I do; :winking_face: :grinning_face_with_smiling_eyes: :winking_face:
@DTRLuke the stock carburetor was running pretty badly and i couldnt really tune it either since the screws were seized so i switched to a 36mm keihin pwk. it was running pretty good actually until i switched a few things including the fuel tank
