  4. Why doesn't my DT125 get a spark?
electricsstatorcdisparkcdi. power. dt
39 Posts 7 Posters 5.8k Views
  • clawsC Offline
    clawsC Offline
    claws
    wrote on last edited by claws
    A bit of a long story for a simple ending but yea.
    So a few days back I was messing with the YPVS and getting it setup since it was making the bike really slow as the valve was pretty much closed. So I got it sorted out but it wasnt completely in tune so I tuned it more and got it all good and did a few wheelies until my idle revs started rising very much.
    At that point I thought that my throttle cable got stuck or something and sorted that out as well. Didn't help anything. After that I took the carburetor out, cleaned the jets and tuned the fuel level just a bit. Then I put everything together and tried to start it and nothing. Then I thought that the spark plug must have gotten wet or something.
    I took the plug out and dried it up. After that I tested if it gets a spark with the plug out of the head and when I turned the main switch on I got an electric shock which startled me a bit. But when i tried to kick start the bike to see if it got a spark, nothing. Nothing at all. I tried another spark plug and nothing.
    So what could be the issue? I think it could be either the stator or the cdi. Not sure yet.
      Common issues on these bikes tend to be, side stand switch, neutral switch and kill switch. Make sure those are good.
      Check the ignition barrel connector block, you may have disturbed it when faffing about.
      Easiest way to sort the power valve out is to take the exhaust off and line the valve up with the port directly.
      clawsC 1 Reply Last reply
      • O Offline
        O Offline
        Change the spark plug anyway. Low cost item and can then be ruled our completely
          clawsC Offline
          clawsC Offline
          claws
          @Calum I could open up the kill switch and see if that is working correctly. I doubt that the main switch or the side stand switch have something wrong with them since the rear light turns on when I flip the power on and I don't have a side stand switch actually
          • O oldman
            clawsC Offline
            clawsC Offline
            claws
            @oldman yea I think I could switch a new plug in when I fix the bike. Just a bit shitty that the iridium plug stopped working after like one month
            • clawsC claws
              NINJAN Offline
              NINJAN Offline
              @claws Iridium plugs tend to have a shorter lifespan over regular plugs. Mainly due to the stronger spark they produce. I used Iridium plugs in my DTR and noticed a definite drop in performance after a month's use. As plugs are as cheap_as_chips they are an easy component to replace. 😉
                clawsC Offline
                clawsC Offline
                claws
                @NINJA kinda disappointing to spend 15 euros for a plug that doesnt even work for a month though. will go with the ngk br9es plug from now on since its like 4 euros
                • clawsC claws
                  NINJAN Offline
                  NINJAN Offline
                  @claws The iridium plugs are cheaper on ebay, especially if you buy 4 at a time like I do; :winking_face: :grinning_face_with_smiling_eyes: :winking_face:
                  https://www.ebay.co.uk/itm/BR10EIX-NGK-Spark-Plug-Sparkplug-Type-Iridium-IX-NEW-No-6801/272479003527?hash=item3f7103a387:g:OWUAAOSwo4pYSYqN
                    I have had the same iridium for years. My starlet has had the same iridium for years too.
                    • D Offline
                      D Offline
                      DTRLuke
                      Yes, not normal for any spark plug to be needing replacement within a month. It'd say something about how your engine is running. Too lean or too rich.
                      • D DTRLuke
                        clawsC Offline
                        clawsC Offline
                        claws
                        @DTRLuke the stock carburetor was running pretty badly and i couldnt really tune it either since the screws were seized so i switched to a 36mm keihin pwk. it was running pretty good actually until i switched a few things including the fuel tank
                        • clawsC claws
                          D Offline
                          D Offline
                          DTRLuke
                          @claws
                          You can buy chinese remade DT carbs, a few people have them on their bikes. A lot probably don't even realise they have a fake carb.
                          declanD clawsC 2 Replies Last reply
                          • D DTRLuke
                            @claws
                            @DTRLuke yeah they’re only 50 pound look decent
                              NINJAN Offline
                              NINJAN Offline
                              @declan £50 quid - BARGAIN!!!
                              • D DTRLuke
                                @claws
                                clawsC Offline
                                clawsC Offline
                                claws
                                @DTRLuke actually paid around 50 pounds for the keihin carburetor
                                  @NINJA yeah it really isn’t a bad price
                                  • clawsC claws
                                    D Offline
                                    D Offline
                                    DTRLuke
                                    wrote on last edited by DTRLuke
                                    @claws The Keihin carb is probably also fake. Most carb's are fake on eBay etc. If you order one directly from Yamaha, then it's most probably OEM, but will be double the price of the fake.
                                    • D DTRLuke
                                      clawsC Offline
                                      clawsC Offline
                                      claws
                                      @DTRLuke no no no i bought the carburetor as a used one that was taken from a ktm exc 125
                                      • clawsC claws
                                        @claws still could be fake
                                          clawsC Offline
                                          clawsC Offline
                                          claws
                                          @declan well yea but since the carburetor works i dont really care
