  4. DT125R stator on DT125RE
15 Posts 4 Posters 2.7k Views
  • B Offline
    B Offline
    Bananper
    I am suspecting my stator to be faulty, and a friend of mine has a stator for DT125R available, so i was wondering if it would fit on my DT125RE, or if it could be made fit.
    Thanks!
    CalumC declanD markus.wM 3 Replies Last reply
    • B Bananper
      Thanks!
      @Bananper unfortunately not, due to the R having different electrics.
      What makes you feel like the stator is faulty? They are pretty reliable, since it's just a winding... Could it not be the rectifier?
      B 2 Replies Last reply
      • B Bananper
        Thanks!
        @Bananper yeah they don’t fit been there done that China does a good looking system for cheap I was going to get one
        B 1 Reply Last reply
        • B Bananper
          Thanks!
          markus.wM Offline
          markus.wM Offline
          @Bananper hi mate, not sure what part of the world you're in but there's a company in UK called west country windings who rebuilt my stator off my old gsx 250 for a very reasonable price and all by mail. You can mail it to them and I had mine returned within about 3 days. I think it cost me about £20 but it was about 15 years ago. They are online. Maybe worth a try.
            B Offline
            B Offline
            Bananper
            @Calum well my bike has a no spark issue and as i said in my other post, the source coil showed a lower reading than the specifications in the haynes manual. 125 ohms, should have been 192-288. I already replaved my rectifier.
              B Offline
              B Offline
              Bananper
              @Calum do you think that the source coil could be my issue?
                I would be reluctant to think so. It's just a coil of wire. Perhaps the pickup. But the coils? I dunno, I've not heard them going wrong through age.
                Put it this way, a lot of this stuff still works on Lambrettas and they weren't theb est built to begin with and are like a million years old.
                  B Offline
                  B Offline
                  Bananper
                  @Calum I got a friend of mine to take of his left side cover with the coils in and everything, put it on mine and it sparked!
                  So i'm looking at what options i got when it comes to getting a new one, as paying 100£+ for one on ebay is too much in my opinion. Any suggestions, are there any aftermarket stators?
                    You can get yours rewound by a specialist.
                      B Offline
                      B Offline
                      Bananper
                      @declan said in DT125R stator on DT125RE:
                      Could you link it to me? :)
                      • B Bananper
                        @Bananper https://www.google.com/aclk?sa=l&ai=DChcSEwi45PSV1MXoAhWFhtUKHZbUD60YABAGGgJ3cw&sig=AOD64_1izRmI2DOHXKWLhyNqlkblXiXRzQ&ctype=5&q=&ved=0ahUKEwj3zPCV1MXoAhWQFcAKHUJECeIQpysIJA&adurl=
                        obviously do your own research into if it will work but looks identical to my one i changed
                          B Offline
                          B Offline
                          Bananper
                          @declan Looks like it only fits the old DTR
                            B Offline
                            B Offline
                            Bananper
                            @Calum Do you know if a TZR stator would fit, isn't it exactly the same engine as the DTRE? They are a lot more common to find on ebay.
                            • B Bananper
                              @Bananper my bad I misread your original post I thought you had a dtr
                              • B Bananper
                                @Bananper I would know i'm afraid.
                                The TZR Belgarda uses a 3MB Engine. I can't remember if I used the coils from that engine on my loom. I would have thought so. But I don't know about the 2RK models. The Belgarda engines should be somewhat scarce.
