  3. Exhaust
  4. Giannelli vs stock
Giannelli vs stock
51 Posts 5 Posters 15.0k Views
    @declan I think I tried that and it didn't work.
    Honest to God, the exhaust joining rubbers did my nut in on my DT. Glad I don't have that anymore.
    @Calum its whats on my bike and many mx guys do it with silicone hoses
      @declan Happy days!
        jonne123
        Does athena exhaust fit all dt 125 r/re/x or do they have differences?
          RE/X are the same. R is slightly different.
            jonne123
            But with little modificarion they fit?
              Yeah, it's the same engine. There are a few mounts that aren't right. And the tail pipe is off every slightly. So needs a joiner.
              Not particularly worth it IMO. Unless it doesn't cost you anything to make the parts and/or the part you're buying is dirt cheap.
              So to confirm.
              • Front mount won't align on the expansion chamber
              • Middle Mount on expansion chamber won't align
              • Rear Silencer doesn't align
                jonne123
                so these
                  Yeah those.
                    jonne123
                    so grinding and welding?
                      Or just some brackets. You will have to have a look on this forum where the mismatch is.
                      I'm pretty sure there is a photo about how far off the end can is.
                      it's not worth it IMO. Just get a DEP pipe that's fitted to the bikes frame.
                        jonne123
                        yes but i bought used one for 125 euros. we have welder so no problem.
                          I can't help feel like the contours are different. So you still need to mount the silencer in a different location. It's not worth the faff.
                            jonne123
                            #36
                            examble here
                            https://www.moto-hame.fi/tehopakoputki-yamaha-dt125rdt125x-athena-p-8028.html
                            the seller said it came with 4bl 170cc big bore kit
                              Hhmm, also says it fits all models.
                              I know there are fitment issues with the DEP Pipe.
                              Personally wouldn't get an Athena exhaust, would go for something else but it says it'll fit.
                                jonne123
                                What do you succest? i dont have money for dep.
                                  Should be able to get a used DEP for that price.
                                    jonne123
                                    But here in finland there is only giannelli or athena pipes used
                                      That's odd that, as I can't say I'd recommend either of those pipes.
                                      I'm sure they are fine. As I say, the DT just isn't a quick bike, so definitely don't spend too much $$$ trying to make it into something it's not.
                                      By all means release some free ponies and just enjoy it for what it is.
                                        jonne123
                                        So the power gain is minimal?
                                          Stock gutted is pretty decent.
                                          The benefit is more weight.
                                          If you are handy with a welder, then I'd look at having your current pipe derestricted.
                                          Check this out.
                                          https://dt125r.co.uk/topic/20/yamaha-dt125re-x-stock-exhaust-pipe
