  3. Exhaust
  4. Giannelli vs stock
Giannelli vs stock
51 Posts 5 Posters 15.0k Views
    Or just some brackets. You will have to have a look on this forum where the mismatch is.
    I'm pretty sure there is a photo about how far off the end can is.
    it's not worth it IMO. Just get a DEP pipe that's fitted to the bikes frame.
      jonne123
      yes but i bought used one for 125 euros. we have welder so no problem.
        I can't help feel like the contours are different. So you still need to mount the silencer in a different location. It's not worth the faff.
          jonne123
          #36
          examble here
          https://www.moto-hame.fi/tehopakoputki-yamaha-dt125rdt125x-athena-p-8028.html
          the seller said it came with 4bl 170cc big bore kit
            Hhmm, also says it fits all models.
            I know there are fitment issues with the DEP Pipe.
            Personally wouldn't get an Athena exhaust, would go for something else but it says it'll fit.
              jonne123
              What do you succest? i dont have money for dep.
                Should be able to get a used DEP for that price.
                  jonne123
                  But here in finland there is only giannelli or athena pipes used
                    That's odd that, as I can't say I'd recommend either of those pipes.
                    I'm sure they are fine. As I say, the DT just isn't a quick bike, so definitely don't spend too much $$$ trying to make it into something it's not.
                    By all means release some free ponies and just enjoy it for what it is.
                      jonne123
                      So the power gain is minimal?
                        Stock gutted is pretty decent.
                        The benefit is more weight.
                        If you are handy with a welder, then I'd look at having your current pipe derestricted.
                        Check this out.
                        https://dt125r.co.uk/topic/20/yamaha-dt125re-x-stock-exhaust-pipe
                          jonne123
                          But i have 1994 pipe and theres something suspious weöding done
                          • J jonne123
                            @jonne123 As cheap as chips;
                            https://www.ebay.co.uk/itm/Yamaha-DT125R-tailpipe-Exhaust-rubber-seal-DT-125-R-RE-X-DT125RE-DT125X-DTR-LC/112769265216?hash=item1a41926e40:g:RdYAAOSw8R9cEtZd
                              jonne123
                              I got hold of giannelli and fmf silencer for 100€
                                jonne123
                                Does giannelli have sound dampening insade? Stock 1994 has maybe
                                • J jonne123
                                  @jonne123 they all do
                                    jonne123
                                    I like the giannelli it makes little bit of power
                                    • J jonne123
                                      @jonne123 I doubt there’s a difference between any of them beside where in the band the power is made
                                        jonne123
                                        Atleast throttle response is little bit better.
