  3. Exhaust
  4. Giannelli vs stock
Giannelli vs stock
51 Posts 5 Posters 15.0k Views
    jonne123
    But here in finland there is only giannelli or athena pipes used
      That's odd that, as I can't say I'd recommend either of those pipes.
      I'm sure they are fine. As I say, the DT just isn't a quick bike, so definitely don't spend too much $$$ trying to make it into something it's not.
      By all means release some free ponies and just enjoy it for what it is.
        jonne123
        So the power gain is minimal?
          Stock gutted is pretty decent.
          The benefit is more weight.
          If you are handy with a welder, then I'd look at having your current pipe derestricted.
          Check this out.
          https://dt125r.co.uk/topic/20/yamaha-dt125re-x-stock-exhaust-pipe
            jonne123
            But i have 1994 pipe and theres something suspious weöding done
            • J jonne123
              @jonne123 As cheap as chips;
              https://www.ebay.co.uk/itm/Yamaha-DT125R-tailpipe-Exhaust-rubber-seal-DT-125-R-RE-X-DT125RE-DT125X-DTR-LC/112769265216?hash=item1a41926e40:g:RdYAAOSw8R9cEtZd
                jonne123
                I got hold of giannelli and fmf silencer for 100€
                  jonne123
                  Does giannelli have sound dampening insade? Stock 1994 has maybe
                  • J jonne123
                    @jonne123 they all do
                      jonne123
                      I like the giannelli it makes little bit of power
                      • J jonne123
                        @jonne123 I doubt there’s a difference between any of them beside where in the band the power is made
                          jonne123
                          Atleast throttle response is little bit better.
