  3. Welcome New Owners!
  4. My new toy.
My new toy.
25 Posts 6 Posters 6.6k Views
    Happy days mate. This could be a rapid little bike then!
    @Calum hopefully. Thank you Calum.
      @Calum do you know anything about the 3rm-30 because I always thought the 20 is the one to have but I can't find much info on the 30?
        I can't remember to be honest. I bought a Zeeltronic and forgot about it.
          @Calum fair enough thanks for your time.
            @markus-w Nice bike - very Foxy!!! 🦊
              @NINJA hey thanks a lot.
              • DTleeD
                DTleeD
                DTlee
                Markus, I also brought a french Import with the 3rm-30. I searched everywhere for info about it and there was hardly anything! I did find something in french which I translated, which basically said it’s Very rare but probably the best CDI available so I’d stick with it. I’ve just done the yvps and put a dep on mine. I’m About to finally get mine on the road so hopefully it’s all good!
                • DTleeD DTlee
                  @DTlee Or get a Zeeltronic for £160 and have complete control over both the ignition timing and YPVS.
                  • DTleeD
                    DTleeD
                    DTlee
                    When I get it on the road I’ll test it. If the cdi holds it back still I’ll be going for the zeeltronic I think 😬
                      I think you'll be fine.
                      The 2000-2005 DTR had a horrible ignition on it 😛
                      But it sounds like yours has been sorted out. So will be interested in seeing how it goes.
                      • DTleeD
                        DTleeD
                        DTlee
                        Went out on it today. With the power valve sorted, Reed switch moved and the dep system on it was loads quicker! Different bike, I was surprise how long the power band was and how much it gained.
                        • DTleeD DTlee
                          @DTlee thanks yes that is all I found one piece that said it's rare and good so looking forward to getting on the road and test it properly.
                          • DTleeD DTlee
                            @DTlee hopefully mine should be pretty much the same then as I have dep too. Yours sounds pretty good. So much fun.
                            DTleeD 1 Reply Last reply
                              DTleeD
                              DTleeD
                              DTlee
                              @markus-w yep compared to the first time I took it out when it was completely stock, it’s a different bike completely now. Plenty fast enough for me and more than enough power in the power band. Have you moved the reed switch out Of the rev gauge?
                              declanD markus.wM 2 Replies Last reply
                              • DTleeD DTlee
                                I wish mine had a restriction I think my restriction is the cdi it’s self 😢
                                  @declan Pssstt....Zeel 😉
                                    @Calum I just got a new exhaust system for my other bike so I’ve missed my chance for now 😂
                                    • DTleeD DTlee
                                      @DTlee my clocks were off the bike when I bought it and I'm now in the process of connecting them back up, bit of a headache as the wires were cut and left in a bit of a mess but I'm certainly going to look at the reed switch when I get to it. I understood that it shouldn't be removed completely or it will affect running so yes I'm going to have to look into that. Thanks Lee.
                                        DTleeD
                                        DTleeD
                                        DTlee
                                        wrote on last edited by DTlee
                                        #25
                                        @markus-w just move the reeds switch from the Rev gauges and tape it up about 6” away from the Rev gauge. Don’t cut it out. Took me 15 mins to do And makes a great difference. Because it used to rev up to about 7500-8000rpm and stop. Now it will happily rev to 11000rpm
