  3. Suspension
  4. front suspension
front suspension
14 Posts 4 Posters 2.0k Views
    jonne123
    how do i stiffen my forks?
    • J jonne123
      NINJAN Offline
      NINJAN Offline
      @jonne123 Stiffer springs and thicker oil.
        jonne123
        where i can get springs some guys have put metal tubes to increase pre tension. i need to try 15w oil
        • autovictorA Offline
          autovictorA Offline
          autovictor
          wrote on last edited by autovictor
          i use some washers for a total of about 1.5cm (0,6 inches). there are also the caps with adjustable preload out there https://www.ebay.it/itm/Preload-Fork-Cap-For-Yamaha-DT125-2004-2005-2006-41mm-Adjustable-Fork-Bolts/264595320406?hash=item3d9b1c2e56:g:R08AAOSw-E5djuOy
          NINJAN markus.wM 2 Replies Last reply
          • autovictorA autovictor
            NINJAN Offline
            NINJAN Offline
            @autovictor Have you tried those???
            autovictorA 1 Reply Last reply
              autovictorA Offline
              autovictorA Offline
              autovictor
              @NINJA no i didn't, but i'm very tempted
              NINJAN 2 Replies Last reply
                NINJAN Offline
                NINJAN Offline
                @autovictor I'm intrigued to find out what difference they make???
                  NINJAN Offline
                  NINJAN Offline
                  @autovictor The vids are a bit 'waffaly' but the general consensus is that they do stiffer the front end, less diving on braking and they also improve cornering. So I guess that they are worth the money and a viable low cost upgrade;
                  https://www.youtube.com/watch?v=kzyY01S_DoI
                  https://www.youtube.com/watch?v=miDjp4H205U&t=2s
                    markus.wM Offline
                    markus.wM Offline
                    @autovictor good call. I didn't know they even existed but I've now read a few reviews and it's all positive. About 20mm of adjustment and some nice anodised colours available. Apparently a noticeable difference and some cheap bling from around £15 upwards. Just added a pair to my shopping list.
                      NINJAN Offline
                      NINJAN Offline
                      @markus-w We'll all look forwards to your review after installation!!! 😉
                        markus.wM Offline
                        markus.wM Offline
                        @NINJA sure, I will keep you posted.
                          autovictorA Offline
                          autovictor
                          i use the washers which are basically the same thing as the adjusters but more unconfortable to set, they do stiffer the suspension but especially on the enduro model (which i have) it's probably better to go with stiffer springs because you are not going to lose stroke. however for the gravel roads i do and a bit of enduro which is far from extreme i haven't got any problem, never went to the stroke end (i'm 65 kg, 143 pounds)
                            jonne123
                            where you put the spacers?
                            • J jonne123
                              NINJAN Offline
                              NINJAN Offline
                              @jonne123 https://www.youtube.com/watch?time_continue=248&v=FC_h27KZOxI&feature=emb_logo
