  3. Suspension
  4. front suspension
front suspension
14 Posts 4 Posters 3.0k Views
  • autovictorA
    autovictorA
    autovictor
    wrote on last edited by autovictor
    i use some washers for a total of about 1.5cm (0,6 inches). there are also the caps with adjustable preload out there https://www.ebay.it/itm/Preload-Fork-Cap-For-Yamaha-DT125-2004-2005-2006-41mm-Adjustable-Fork-Bolts/264595320406?hash=item3d9b1c2e56:g:R08AAOSw-E5djuOy
    NINJAN markus.wM 2 Replies Last reply
    • autovictorA autovictor
      @autovictor Have you tried those???
      autovictorA 1 Reply Last reply
        autovictorA
        autovictorA
        autovictor
        @NINJA no i didn't, but i'm very tempted
        NINJAN 2 Replies Last reply
          @autovictor I'm intrigued to find out what difference they make???
            @autovictor The vids are a bit 'waffaly' but the general consensus is that they do stiffer the front end, less diving on braking and they also improve cornering. So I guess that they are worth the money and a viable low cost upgrade;
            https://www.youtube.com/watch?v=kzyY01S_DoI
            https://www.youtube.com/watch?v=miDjp4H205U&t=2s
              @autovictor good call. I didn't know they even existed but I've now read a few reviews and it's all positive. About 20mm of adjustment and some nice anodised colours available. Apparently a noticeable difference and some cheap bling from around £15 upwards. Just added a pair to my shopping list.
                @markus-w We'll all look forwards to your review after installation!!! 😉
                  @NINJA sure, I will keep you posted.
                  • autovictorA
                    autovictorA
                    autovictor
                    i use the washers which are basically the same thing as the adjusters but more unconfortable to set, they do stiffer the suspension but especially on the enduro model (which i have) it's probably better to go with stiffer springs because you are not going to lose stroke. however for the gravel roads i do and a bit of enduro which is far from extreme i haven't got any problem, never went to the stroke end (i'm 65 kg, 143 pounds)
                      jonne123
                      where you put the spacers?
                      • J jonne123
                        @jonne123 https://www.youtube.com/watch?time_continue=248&v=FC_h27KZOxI&feature=emb_logo
