  4. Clutch bell
Clutch bell
19 Posts 6 Posters 1.5k Views
  • S Offline
    Where to get one? Fleabay abounds with worn out ones, but no good ones that I can find 😐
    Where are good suppliers of new parts?
    Cheers peeps!
    • S Offline
      P.S. mine has dimples on one side of the bell/basket teeth. I’m guessing that this is wear, not design?...
        What's a clutch bell?
        You mean the basket? Or the pressure plate?
        I'm not sure I understand what you are after?
          jonne123
          atleast in Finland Clutch bell ( kytkinkello) means clutch basket.
          • NottsbikerN Offline
            NottsbikerN Offline
            Depends on the state of the bike. If its to get it back on the road cheaply look on ebay, if its to keep it in grade-A condition I'd buy a new one from Yamaha
              NottsbikerN Offline
              Hmmn maybe not - Yamaha want £429 for a new one!
              • NottsbikerN Nottsbiker
                @Nottsbiker :weary: Ouch!
                • S Offline
                  Wow! Yeah bell, basket, I know them as both. Wow. How much?!
                  The dimples I’ve got are so perfect they seem ‘made’, not wear. All the ones on eBay or worn with slots and look less precise...
                    So the Haynes manual describes wet and dry paper to alleviate the issue. How far gone is it?
                    • S Offline
                      Just had a nother look in the cold light of afternoon. It’s nearly a mil deep on upper (left of bell) where the rotation pushes against it. I’ve never noticed (or looked for) wear in the past, so I don’t know how much is bad.
                      Also the bike is new to me and I don’t think the last abuser did a good job of rebuilding it 🙄
                        A millimeter is not a lot tbf. My Rotax basket is a lot worse and operates fine.
                        If it's causing running issues, some wet and dry ought to fix that.
                          @Calum yeah they can be pretty gnarly and still operate as normal
                            NottsbikerN Offline
                            If you are careful you can file them flat again but obviously this will allow the plates to rotate more than normal and will then wear it out again more quickly.
                            My 900 Monster would struggle with this as the clutch runs in air and would make even more noise than it already does, however the DT-R one should be fine for a few more thousand miles
                            • S Offline
                              Cheers guys! I’m still not decided on whether to file it now while it’s apart or try it first. Gut says do it now and do it right 🙂
                              The way I see it is that it’s smooshed down that far anyway, all I’m doing is removing the bits that stick up and prevent smooth travel...
                              What you guys think?...
                                Yeah, it's aluminium so just wet and dry. No need for aggressive filing.
                                  @SpookDog just be careful personally I would leave it
                                    D Offline
                                    D Offline
                                    Filed plenty in past. A mates kx was that bad he had to rev it, when stopping in gear to stop it stalling : 0 just be carefull to take the same amount off each clutch finger. Otherwise they won't engage with the clutch plates properly.
                                    • S Offline
                                      Gotchya, the wear is so even it should be straight forward.
                                      The Haynes I have says to use ‘judicial’ filing. Does that mean I have to wear a grey wig and robes😜
                                      • S Offline
                                        Easy job. Put it in a vice with a small wood block to take the pressure off of the ‘fingers’ (also used to support the end of file to keep it square) and breezed it. Didn’t even need the wig🤪
                                        Finish off with a flat needle file & wet n dry...
                                        Just needed the confidence that people have done it before and it’s doable...
