  3. Welcome New Owners!
  4. New member
New member
25 Posts 5 Posters 4.1k Views
  • K Offline
    K Offline
    kevb1967
    Hi just joined today as just got another DT 2002 after my last one 33 years a go
      Hello there!
      Welcome to the forum.
      That's certainly a long time ago? What DT did you have back then? An mx?
      K 1 Reply Last reply
        Hello there!
        K Offline
        K Offline
        kevb1967
        @Calum had a DT125 MK1 black stage 3 tuned by slipsteam kent
          @kevb1967 said in New member:
          DT125 MK1
          The LC?
          • K Offline
            K Offline
            kevb1967
            XIYL7888.JPG new one having a few problems does 65-70 mph in 5th but when you go to 6th nothing happens also only restarts when hot on full throttle mods new front pipe .read switch removed from housing,6in away from Speedo, read block rubber reshaped carb ,restored std has main jet 240, model 3RML-010 Portuguese ? CDI 3RM-30 any suggestions
            Louis-DT-WRL markus.wM 2 Replies Last reply
            • K kevb1967
              Louis-DT-WRL Offline
              @kevb1967 not enough power to pull the gear. Probably need a smaller front sprocket
              • K Offline
                K Offline
                kevb1967
                thanks I will check the number of teeth on the front sprocket do you know what is std
                • K kevb1967
                  markus.wM Offline
                  markus.wM Offline
                  @kevb1967 welcome, very nice looking DT you have. My French import has the 3rm-30 CDI and I understand that they're one of the best.
                  • K Offline
                    K Offline
                    kevb1967
                    thanks how high does yours rev to
                    • K kevb1967
                      markus.wM Offline
                      markus.wM Offline
                      @kevb1967 mine has no clocks and it has the 170 kit but it does have very good top end and revs freely. Also the powervalve is pinned open so after about 6k it sort of comes alive. Is your powervalve working ok?
                        Unfortunately, the 2002 models were heavily restricted. Even with the derestrictions you can still expect problems.
                        Get yourself an aftermarket CDI and all those problems will go away and it'll fly through the gears.
                        Looks tidy though!
                          Looks tidy though!
                          K Offline
                          K Offline
                          kevb1967
                          @Calum thanks any links to them
                            https://www.zeeltronic.com/page/yamaha.php
                              K Offline
                              K Offline
                              kevb1967
                              @Calum is a 3rm-20 CDI any good as i see they are not restricted
                              • K kevb1967
                                markus.wM Offline
                                markus.wM Offline
                                @kevb1967 no it's not restricted but if you have the 3rm-30 that is the best one, only available on the French models from 1999-2002 and apparently quite special and rare. Here's a link to a German website which explains the different CDI's. http://dtpedia.de/mediawiki/index.php/CDI_Steuerteile
                                I don't think your problem is a restriction problem, only starting on full throttle from hot? Maybe fuelling or maybe compression? Sounds like your bike is a full power unrestricted french import.
                                • K Offline
                                  K Offline
                                  kevb1967
                                  hi thanks mine seams to be portages' but registered as new 2002 in the uk ,its a 3rml-010 and 4bl engine stamp, 3rm-30 cdi ,goes like a rocket to 70mph in 5th, but wont pull hard and or enter the power band in 6th gear and only revs to 9000 but not in 6th ,16/57 gearing refurbished carb std 140 main jet, read switch removed away from Speedo, snorkel removed from air box, read block rubber reshaped big one exhaust any ideas anyone .so near but so far some one musts know ?
                                  • K kevb1967
                                    @kevb1967 I mean, it's a 125.doing 70 like that. Could just be gearing.
                                    • K Offline
                                      K Offline
                                      kevb1967
                                      16/57 gearing is this std ? should it rev over 9000 revs
                                        The 2000-2004 era were notoriously restricted.
                                        Also appreciate that a lot of these bikes were ridden by youngsters weighing 60-70kgs.
                                        • K Offline
                                          K Offline
                                          kevb1967
                                          r u saying i need to loose weight , am at 12 st 12lb so down hill it would be faster ?
