  3. Welcome New Owners!
  4. New member
New member
25 Posts 5 Posters 5.5k Views
  • K
    K
    kevb1967
    XIYL7888.JPG new one having a few problems does 65-70 mph in 5th but when you go to 6th nothing happens also only restarts when hot on full throttle mods new front pipe .read switch removed from housing,6in away from Speedo, read block rubber reshaped carb ,restored std has main jet 240, model 3RML-010 Portuguese ? CDI 3RM-30 any suggestions
    Louis-DT-WRL markus.wM 2 Replies Last reply
    • K kevb1967
      Louis-DT-WRL
      Louis-DT-WRL
      @kevb1967 not enough power to pull the gear. Probably need a smaller front sprocket
      • K
        K
        kevb1967
        thanks I will check the number of teeth on the front sprocket do you know what is std
        • K kevb1967
          @kevb1967 welcome, very nice looking DT you have. My French import has the 3rm-30 CDI and I understand that they're one of the best.
          • K
            K
            kevb1967
            thanks how high does yours rev to
            • K kevb1967
              @kevb1967 mine has no clocks and it has the 170 kit but it does have very good top end and revs freely. Also the powervalve is pinned open so after about 6k it sort of comes alive. Is your powervalve working ok?
                Unfortunately, the 2002 models were heavily restricted. Even with the derestrictions you can still expect problems.
                Get yourself an aftermarket CDI and all those problems will go away and it'll fly through the gears.
                Looks tidy though!
                K 1 Reply Last reply
                  Looks tidy though!
                  K
                  K
                  kevb1967
                  @Calum thanks any links to them
                    https://www.zeeltronic.com/page/yamaha.php
                      K
                      K
                      kevb1967
                      @Calum is a 3rm-20 CDI any good as i see they are not restricted
                      • K kevb1967
                        @kevb1967 no it's not restricted but if you have the 3rm-30 that is the best one, only available on the French models from 1999-2002 and apparently quite special and rare. Here's a link to a German website which explains the different CDI's. http://dtpedia.de/mediawiki/index.php/CDI_Steuerteile
                        I don't think your problem is a restriction problem, only starting on full throttle from hot? Maybe fuelling or maybe compression? Sounds like your bike is a full power unrestricted french import.
                        • K
                          K
                          kevb1967
                          hi thanks mine seams to be portages' but registered as new 2002 in the uk ,its a 3rml-010 and 4bl engine stamp, 3rm-30 cdi ,goes like a rocket to 70mph in 5th, but wont pull hard and or enter the power band in 6th gear and only revs to 9000 but not in 6th ,16/57 gearing refurbished carb std 140 main jet, read switch removed away from Speedo, snorkel removed from air box, read block rubber reshaped big one exhaust any ideas anyone .so near but so far some one musts know ?
                          • K kevb1967
                            @kevb1967 I mean, it's a 125.doing 70 like that. Could just be gearing.
                            • K
                              K
                              kevb1967
                              16/57 gearing is this std ? should it rev over 9000 revs
                                The 2000-2004 era were notoriously restricted.
                                Also appreciate that a lot of these bikes were ridden by youngsters weighing 60-70kgs.
                                • K
                                  K
                                  kevb1967
                                  r u saying i need to loose weight , am at 12 st 12lb so down hill it would be faster ?
                                  • K kevb1967
                                    @kevb1967 That's not a bad weight, I think I used to be super light, and I swear I got 85mph out of my DTR when I was 17.
                                    Years later, £££ spent on tuning, I'm lucky if I can get 70 out of it. Yeah, I put on weight. My RS on the other hand flies!
                                      @Calum losing weight is the biggest upgrade for performance
                                      • K
                                        K
                                        kevb1967
                                        just realized I have a English speedo but it measures distance in km does any one know how to correct this please .
                                        • K kevb1967
                                          @kevb1967 it sounds like someone has fitted a Speedo drive adapter to it to convert from mph to kmh, it fits to the back of the clocks to change the gearing then the cable fits into it. Or maybe on the wheel end but mine was on the clocks. I bought one a few years ago for my nc30 jap import to convert kmh to mph and was quite an expensive bit of kit, cost me around £100 so if that is the case you could probably sell it if you can put it on eBay France or anywhere in Europe.
