  3. Derestricting
  4. YAMAHA DT 125 E SWISS
26 Posts 5 Posters 11.9k Views 1 Watching
    @DylanDT219 You need to check the crankcase serial number, which for a 91, will most likely be a 4BL - 000
    DylanDT219D
    DylanDT219D
    DylanDT219
    wrote on last edited by DylanDT219
    @Darty mine is 3ME-0007 if you want i can send to you a photo
    • DylanDT219D DylanDT219
      @DylanDT219 don't focus on 180 degree stuff. Whip the exhaust off and make sure the powervalve is flush with the exhaust port when the valve opens fully. To test the top end you can pin it open and disconnect the valve.
      DylanDT219D 2 Replies Last reply
        DylanDT219D
        DylanDT219D
        DylanDT219
          DylanDT219D
          DylanDT219D
          DylanDT219
          okay let's say my valve is perfectly adjusted what should I do? change cdi? if so with which one?
            @DylanDT219 Make sure the inlet and exhaust tracts are free from restrictions. Ensure the linked above derestrictions are in place and make sure the engine is healthy.
            Is the bike using stock gearing?
            DylanDT219D 1 Reply Last reply
              DylanDT219D
              DylanDT219D
              DylanDT219
              @Calum maybe you still have not understood the sport exhaust and it is no longer original I have mounted ujna firebox athena in addition to this on the site we wrote that inlet before 1991 there are no restrictions and then I do not know if the gearbox is original since I have never opened the engine and then I do not think that there are modified changes for the dtr
                By restrictions mate, I mean blockages. Like is there leaves and dirt in the inlet tract. As well as exhaust. So yes it may be an aftermarket exhaust, but if it's blocked then that will cause poor performance.
                And by stock gearing, I mean the front and rear sprockets.
                Sorry for the confusion.
                • S
                  ‘Lost in translation’ springs to mind...
                  How long has your bike been stuck at 80kph? (60 mph is slow and wrong)
                  Was it faster before? Has it always been so since tha 170 Athena kit? Did it come as a 170? More history is needed...
                  Hazelnut brown is too dark, no?. Should be ‘tan’ ideally?? Been a while since I’ve had my last stroke (2) ☠️
                    Even if the fueling was slightly off it should be better than that. That said the Athena kit is a bit shite.
                      DylanDT219D
                      DylanDT219D
                      DylanDT219
                      ahhh okay anyway stock gearing for dirt don't worry i checked and it's all clean
                        DylanDT219D
                        DylanDT219D
                        DylanDT219
                        @SpookDog my bike has always been blocked both with the original cylinder and with the 170cc it has always done less than 80 km / h. the 170cc arrived new from a german site with everything you need i still have the box ...
                          • S
                            If it’s the same with two different cylinders and exhausts it is obviously something else. Either the carb or ignition.
                            What does it max out at on revs?
                            Does it rev up smoothly?
                              DylanDT219D
                              DylanDT219D
                              DylanDT219
                              @SpookDog you rev ​​up without problems, before I turned the YPVS by 180 ° it reached a maximum of 8 thousand rpm, but anyway this is the problem here someone has to tell me if they know any mechanical block so inside or outside the engine and electronically
                                Reed switch?
                                  Reed switch?
                                  DylanDT219D
                                  DylanDT219D
                                  DylanDT219
                                  @Darty che interruttore?
                                    Reed switch?
                                    DylanDT219D
                                    DylanDT219D
                                    DylanDT219
                                    @Darty said in YAMAHA DT 125 E SWISS:
                                    Reed switch?
                                      Just read the derestriction guide that was the first post.
                                        @Calum 🤡 me after making that post
                                        • S
                                          Yeah, go through the derestriction guide.
                                          Only when you know it’s properly deristricted can you address why you’re only getting 55-60 mph from your bike. Cause that’s not right restricted or not...
