  3. Derestricting
  4. YAMAHA DT 125 E SWISS
26 Posts 5 Posters 11.9k Views 1 Watching
    Even if the fueling was slightly off it should be better than that. That said the Athena kit is a bit shite.
      By restrictions mate, I mean blockages. Like is there leaves and dirt in the inlet tract. As well as exhaust. So yes it may be an aftermarket exhaust, but if it's blocked then that will cause poor performance.
      And by stock gearing, I mean the front and rear sprockets.
      Sorry for the confusion.
      DylanDT219D
      DylanDT219D
      DylanDT219
      ahhh okay anyway stock gearing for dirt don't worry i checked and it's all clean
        ‘Lost in translation’ springs to mind...
        How long has your bike been stuck at 80kph? (60 mph is slow and wrong)
        Was it faster before? Has it always been so since tha 170 Athena kit? Did it come as a 170? More history is needed...
        Hazelnut brown is too dark, no?. Should be ‘tan’ ideally?? Been a while since I’ve had my last stroke (2) ☠️
        DylanDT219D
        DylanDT219D
        DylanDT219
        @SpookDog my bike has always been blocked both with the original cylinder and with the 170cc it has always done less than 80 km / h. the 170cc arrived new from a german site with everything you need i still have the box ...
        • DylanDT219D DylanDT219
          • S
            If it’s the same with two different cylinders and exhausts it is obviously something else. Either the carb or ignition.
            What does it max out at on revs?
            Does it rev up smoothly?
            DylanDT219D 1 Reply Last reply
              DylanDT219D
              DylanDT219D
              DylanDT219
              @SpookDog you rev ​​up without problems, before I turned the YPVS by 180 ° it reached a maximum of 8 thousand rpm, but anyway this is the problem here someone has to tell me if they know any mechanical block so inside or outside the engine and electronically
                Reed switch?
                DylanDT219D 2 Replies Last reply
                  Reed switch?
                  DylanDT219D
                  DylanDT219D
                  DylanDT219
                  @Darty che interruttore?
                    Reed switch?
                    DylanDT219D
                    DylanDT219D
                    DylanDT219
                    @Darty said in YAMAHA DT 125 E SWISS:
                    Reed switch?
                      Just read the derestriction guide that was the first post.
                        @Calum 🤡 me after making that post
                        • S
                          Yeah, go through the derestriction guide.
                          Only when you know it’s properly deristricted can you address why you’re only getting 55-60 mph from your bike. Cause that’s not right restricted or not...
