  4. Yamaha DT 125R 1994 project
48 Posts 7 Posters 15.6k Views 1 Watching
  • J jonne123
    Well it had rebuild top end and i changed the filter right away but didn´t realise that there was sand in the intake until month ago i cleaned it. Also the engine was making weird side noise probably from crankshaft. There was oil and mixture was rich.
    #31
    @jonne123
    Sorry dude! Don’t take me to heart. I’m on my 4th beer! I don’t mean to come across as patronising ...
      jonne123
      But i didnt do a burnout.
      • J jonne123
        @jonne123
        YouTube & your back tyre says otherwise! 😄
        An engine rebuild is always around the corner on a second hand bike, no matter what the previous owner says. If you do as good a job with the engine as you did with the rest of the bike, you’ll end up with a good, tight bike. Just run it in on less than 90% throttle!! 😜 ...
          jonne123
          #34
          Yeah... But it was like month after burnout. The engine has always made weird side noise. But it would really been sad if it happened during next summer. The bearing would failed. Also the needle bearing is totally worn and piston rings. Remember to clean your air filter!
          But now plans for the project:
          -Fix rust and paint some parts.
          -Clean aluminium parts.
          -Fix engine
          -Replace worn parts.
          -Sticker kit or wrap for plastic parts.
          -Possible some tuning parts.
          I´m open for suggestions!
          • J jonne123
            -Fix engine
            @jonne123 Fix the engine is the first point of call. Find out why it failed as well.
              jonne123
              I know that the crankshaft bearing failed. But there could be something else like a bearing.
              • J jonne123
                @jonne123 Yes, but WHY did the crank bearing fail?
                There is no point in rebuilding it if you don't understand why it failed.
                  #38
                  I’m guessing that the weird side noise was worn out main bearings 🙄 ...
                  @jonne123
                  I’d replace every bearing and seal in the engine, crank conrod as well, and if you’re gonna do that you might as well do the bore and piston rings @ least...
                    jonne123
                    Yeah the previous owner said it had engine rebuild but im guessing he meant top end because the engine bolts were so stuck and the engine was so dirty. Going to buy wössner piston and connecting rod. Good main bearings and seal.
                    • J jonne123
                      @jonne123
                      Wossner and forged pistons are good, but you need to get the clearance right to allow for expansion. I understand buying the best you can, but is it really necessary? If you’re rolling in ca$h ignore me! 🙂 Just don’t fall into the trap of thinking expensive is best...
                        jonne123
                        The cylinder is going to shop. And price isnt that bad and prox quality has sometimes up and downs. And i suppose they are better because they are made with strong material and theyre forged. The ktm guys here use wössner pistons. And i know that i need to let the engine warm really well and also idle after ride.
                          jonne123
                          So the crankshaft bearing missed half of the needles. Also the main bearings had slack. So the engine wasnt rebuild recently as the owner said.
                            The big end bearing you mean?
                            People probably overlook that as it's not something you can easily do at home as the crank needs balancing afterwards!
                            Pity. The Yamaha Con Rod kids don't come with the shaft either, so if you've nackered up the eye then you'd be looking at getting another crank.
                            Was it salvageable do you know?
                              jonne123
                              I will buy connecting rod kit had bring them to local machine shop. They will put it together and balance.
                              • J jonne123
                                @jonne123 What about the crank pin?
                                  jonne123
                                  https://www.moto-hame.fi/kiertokanki-yamaha-dt125rrex-tzr125-wssner-p-11810.html
                                  • J jonne123
                                    @jonne123 Spot on!
                                    There was some concerns a while back with Wossner rods being made in China.
                                    But I've ran a few of them and not had any dramas.
                                      jonne123
                                      I figured if im going to rebuild the engine that i just put quality parts.
