  4. Messed up on my build need radiator advice
46 Posts 5 Posters 8.6k Views
    @dan28 according to the vapor unit, it was sitting at 100 celcius in traffic. Which seems way too hot.
    dan28
    @calum said in Messed up on my build need radiator advice:
    Using the twin rad setup that you have now how far up does it go when in traffic
      @spookdog not sure on my temp gauge when offroading in summer I would consider 110 Celsius to be time for cooling down since the motor would be smelling very hot
      @declan
      It’s weird, my temp gauge doesn’t rise much at all in stop~start nightmare traffic. What does happen is my gear change gets ’sticky’, it won’t go into neutral without a struggle. That’s when my engine smells hot.
      Trouble is a radiator is doing next to nothing if it doesn’t have any airflow forcing convection. Sitting in traffic is the worst possible scenario. I don’t have any cooling problems, if I did I’d put 1 or 2 12v fans on the radiator. The kind you get in computers for CPU cooling but bigger, there’s loads out there. have a temperature actuator probe that sits in the fins of the radiator, so they only come on when needed. If the problem was bad I’d shroud the fans th the radiator as well...
        @declan
        @spookdog the sticky gear changes might be your clutch overheating and putting pressure on the gearbox
          @declan
          Makes sense, especially when I ride the clutch like a numpty, rather than putting it in neutral, or just slowvertaking the stagnant traffic! 🙂
            @declan
            @spookdog meh clutches are dirt cheap and take 10 minutes to do and they last year's so just ride that clutch lol
              @declan
              I use it as a foot warmer in the winter!🥶
                @declan
                @spookdog yeah and the pipe is the hand warmer
                  dan28
                  @calum have you got your lanza radiator yet
                  Could you measure it please
                  • D dan28
                    @dan28 I did, but it is WIDELY different to the OEM Lanza radiator.
                    I wonder if there was a translation error 😮
                      dan28
                      You can buy a pair of after market lanza rads for approx 150 on the non filler side is a lot longer
                      • D dan28
                        @dan28 And the filler side is a lot thicker.
                          dan28
                          If it's thicker that's good it has a thicker core so will cool it better
