  4. Cutting back ?
Cutting back ?
43 Posts 4 Posters 11.3k Views
  • DTleeD DTlee
    @calum cheers will have a look into it
    the power valve pipe needs to be air-leak free. If it looks old and dry or cracked, replace it..
    My number plate is dripping with shitty old 2/ from the silencer. It’s just the way it is with 2/‘s. Even if you pre-mix your fuel & oil...
    Wet plug could just as easily be to much fuel or the ignition breaking down. It also depends if the engine was up to temperature? Cold engine makes for wet plug, in my experience...
    • DTleeD DTlee
      Ah okay. When I said full power I mean I have moved the Reed switch away and the power Valve is working properly. It’s a french import with the better cdi from what I can remember researching. It’s was revving perfectly in the past, right up to 11000rpm. It just seems to be at full throttle between 8-9000 RPM. Maybe I’ll give the card a clean first and go from there.
      Thanks
      @dtlee said in Cutting back ?:
      What do you mean by that? Has the problem happened since this or just lately all of a sudden?...
      Cheers bud
      DTleeD 1 Reply Last reply
        Cheers bud
        DTleeD
        DTleeD
        DTlee
        wrote on last edited by DTlee
        @spookdog thanks for your advice. I moved the Reed switch out from the Rev counter a long time ago and it’s always been fine. The problems I’m having now are more recent. Will have a look into the ignition and carb jets and see how I get on cheers
        • DTleeD DTlee
          @dtlee
          That’s an electronic rev limiter isn’t it? I think the 1997 onwards bikes have them? Y/N? Maybe that connectors the problem?
          I have an 1988 onwards wiring loom/CDI. So I wasn’t sure what you meant 🙂
          A little back history is really helpful. When (& if!) it last ran proper, any changes you’ve made, Bada bada, bing bing! You get the pic? Helps diagnose problematic changes...
          Carb jets won’t be the problem, they don’t change from right to wrong. Air leaks will, as will crank seals. I doubt that it’s that though. Not if the bearings aren’t noisy...
          Seriously, I’d check the rev limiter mod
            @dtlee
            It sounds like it could be breaking down, if that’s possible...
            Sorry, couldn’t see or reach to type in my last post on my phone screen...
              DTleeD
              DTleeD
              DTlee
              @spookdog haha cheers will investigate a bit more and update
              • DTleeD
                DTleeD
                DTlee
                Is there a way to check if the ignition is breaking down? I’ve checked everything mentioned above and cleaned the carb out etc. But still the book it’s cutting back intermittently at about 8000rpm. Before I split the casing and check seals I want to make sure I’ve checked everything else.
                It seems to run perfect for about 20mins riding the then seems to start and progressively gets worse. Could this be as it warms up the ignition is failing
                TIA
                • DTleeD DTlee
                  TIA
                  @dtlee as electronics warm up the resistance changes I'd hazard a guess with the problems your having you might have a faulty ignition coil as the coil warms up it might be out of spec this is easily checked with a multimeter via the Haynes manual, my bike cuts back at the same rpm never been able to remedy it- edit when I say ignition coil I mean the physical coil on the stator not the ht coil although that also can be an issue when it warms up
                    DTleeD
                    DTleeD
                    DTlee
                    @declan ah cool I’ll give that a go. So you’ve never managed to fix your problem of cutting back. It’s driving me mad I need to try and work it out
                    • DTleeD DTlee
                      TIA
                      @dtlee I had this recently on my DT when I replaced the perfectly working coil for a Chinese "Racing" coil. It worked fine for the first 100 miles then just refused to rev properly.
                      Getting a nice genuine coil seemed to have fixed it.
                      • declanD
                        @dtlee yeah gonna try switching my main jet to a 240 see if that does anything gonna be a whole though as the engine is under the knife
                          DTleeD
                          DTleeD
                          DTlee
                          @calum I’m hoping this does the trick for me too where did you buy yours from?
                            DTleeD
                            DTleeD
                            DTlee
                            @declan I was thinking about jetting too but don’t want to mess with it too much as It used to ride fine before so I don’t think it will help me out
                            • DTleeD DTlee
                              @dtlee yeah in your case wouldn't mess with jets it's almost certainly electrical
                                DTleeD
                                DTleeD
                                DTlee
                                @declan just another though, I should probably checked that everything is earthed properly and that’s it’s not just something stupid like that? Do you know where the earthing point are on the bike. I had a quick look but couldn’t see anything obvious?
                                  @dtlee Ignition coil should have an earth, voltage rectifier should have one and the battery terminal is earthed.
                                    DTleeD
                                    DTleeD
                                    DTlee
                                    @calum cheers I’ll check that just Incase it’s some thing stupid. I’m doing a 100 mile long distance trial in a couple or weeks so want it running right if I can get it to
                                    • DTleeD
                                      DTleeD
                                      DTlee
                                      #30
                                      Is there an easy way to temporarily disable the oil pump? I just want to check if it’s not packing up? It all looks correct but my plug is still oily and the bikes still cutting back at around 6-7krpm. I’ve checked the power valve isn’t the problem by pinning it open, took it for a ride and was still having the same issue. I was thinking of trying to pre mix the fuel and disable to oil pump to work out of its this causing the problem.
                                      I’m running out of ideas with it. Failing this I guess it’s the ignition breaking down.
                                      ( I have cleaned out the carb, fuel line and the tank also and now put back on the original exhaust )
                                      Any ideas I’d be grateful
                                      • DTleeD DTlee
                                        #31
                                        @dtlee @dtlee
                                        I stuck the outlet (skinny) pipe into the inlet (fatter) pipe to cause a continuous loop. Been like that and ok for a 1000 miles, just don’t forget to block the inlet manifold oil inlet. I just cut and folded over some pipe, then zip tied it.
                                        It stopped messing it’s pants all over the number plate now as well since I’ve been on pre mix...
                                        I can’t remember what I’ve asked you before, but t did you do anything to the bike before it started happening? Even if it was a month before or seems irrelevant?...
                                          @dtlee @dtlee
                                          @spookdog
                                          Did you remove and clean the outside of the needle valve tube? You tap it in and up through the throttle valve body to remove it. Mine was cemented up with micro fine sand stuff...
                                          P.S. Did this come on all of a sudden or gradually get worse?...
                                          DTleeD 2 Replies Last reply
