  4. My DT125 80s Yz style DT200 build one to watch!
233 Posts 17 Posters 115.3k Views 3 Watching
    @mhbikesnbits
    It was only an old Audi 90 10v that I went OCD on. I put a gas flowed head on it with a fat cam and lowered it. Some horrible little crackhead weighted it in when I got made homeless and wasn’t around, back when the price of scrap went crazy (2010?)
    Shtuff happens! 🤨 ...
    M Offline
    M Offline
    mhbikesnbits
    @SpookDog what a shame bet you were gutted when you found it was gone
    • M mhbikesnbits
      @markus-w cheers pal I hope it’s going to look quality the money I’ve spent so far 😂, it is a 200 e engine yes unsure what the stock size from the factory is tbh or if it’s been bored out or anything
      markus.wM Offline
      markus.wM Offline
      @mhbikesnbits I think standard is 66mm.
      M 1 Reply Last reply
        M Offline
        M Offline
        mhbikesnbits
        @markus-w can’t wait kick it in tbh see what the engine can do
        • M mhbikesnbits
          markus.wM Offline
          markus.wM Offline
          @mhbikesnbits I've just done the maths on it. A standard 200cc barrel is actually 195cc (65.98mm piston) a 68mm bore would make it 207cc so a difference of 12cc. Should be quite noticeable.
            M Offline
            M Offline
            mhbikesnbits
            @markus-w you’ve got be excited now 😂
            • M Offline
              M Offline
              mhbikesnbits
              This gets the rattle can treatment it’s only for holding a pipe 😂
              Bit sloppy tbh compared to other things but going to go with a silver paint, may get one later down the Line powder coated, just want to get that engine in the frame asap
              • M Offline
                M Offline
                mhbikesnbits
                #147
                When we had a nice bout of sun the other day I sat in the garden, and started the lovely job of polishing the lower triple clamp.
                Pictures don’t really show the finish very good looks far better in person
                I started with 200 wet and dry and worked my way up to 1000 and finished with a hand polish of some mothers and mag.
                The top of the clamp is black powder coated
                Once the engines dropped in I can get the clamps in because the weight of them will probably drag the frame over now.
                My next task will be probably getting all the handle bars in the and switch gear. I’m going with some pro taper gear for the handle bars.
                • M mhbikesnbits
                  #148
                  @mhbikesnbits
                  It definitely warrants better treatment! 😜
                  Poor things always seem to corrode under the pipe, before the clamp...
                  But yeah! Bung it on!!...
                  PS. You gonna lacquer the bottom yoke?...
                  M 2 Replies Last reply
                    @mhbikesnbits
                    M Offline
                    M Offline
                    mhbikesnbits
                    @SpookDog now I’m thinking make one on the cnc machine would look pretty bad ass
                      @mhbikesnbits
                      M Offline
                      M Offline
                      mhbikesnbits
                      @SpookDog lacquer… hmm never give it a thought to protect the shine ?
                        Bottom yokes have come up nicely! It should hold its shine for a wee while but it's always the way with those things.
                        The pro taper handlebars are nice to be fair.
                          M Offline
                          M Offline
                          mhbikesnbits
                          @Calum bike will be kept inside and probably only ride on the nicer weather days so hopefully this will help it last longer
                          • M mhbikesnbits
                            markus.wM Offline
                            markus.wM Offline
                            @mhbikesnbits still won't take long to lose the shine. Lacquer would work well. It looks really good polished and I really don't want to come across like I'm picking but would it not look better with the top and bottom yokes the same colour? IE both black with the chrome forks? Personal preference I know but I'm trying to picture it in my head.
                              M Offline
                              M Offline
                              mhbikesnbits
                              @markus-w hmm maybe could try the lacquer, I’m going with the black top polished bottom as that was the style it was on the 80s yzs
                                M Offline
                                M Offline
                                mhbikesnbits
                                #155
                                @markus-w maybe this will give you abit more of idea what it would look like,
                                I have a little think about the lacquering and my only issue is paint doesn’t like smooth surfaces so would it end up getting lacquer peel ?
                                markus.wM CalumC 2 Replies Last reply
                                • M mhbikesnbits
                                  markus.wM Offline
                                  markus.wM Offline
                                  @mhbikesnbits fair enough it is the yz look you are going for. Does look good.
                                  • M mhbikesnbits
                                    markus.wM Offline
                                    markus.wM Offline
                                    @mhbikesnbits yes I know what you're saying about peeling because that would look awful. I polished my brake calipers and opted against lacquer for that reason. But I realised after that they use lacquer on alloy wheels on cars, not sure which lacquer but that doesn't peel.
                                    • M mhbikesnbits
                                      @mhbikesnbits Yes! That looks so good polished!
                                      I am looking forward to seeing this progress!
                                      Keep up the updates.
                                        M Offline
                                        M Offline
                                        mhbikesnbits
                                        @Calum cheers buddy will keep it updated as much as I can, getting to the point were more moneys going need spending and quite abit of it tho 😅
                                        • M Offline
                                          M Offline
                                          mhbikesnbits
                                          Not sure about the silver, I have seen them on the standard silver engines but in black and they look good so I thought I would inverse that.
                                          Think I will get one done in black powder coat
