  3. Off Topic
  4. 200cc crankcase conversion
10 Posts 7 Posters 2.8k Views
  • Stevie WonderS Offline
    Stevie Wonder
    Is there anyone here who could or knows someone that’d one day bore it may cases to accept WR200 3xp top end and crank? And what they’d charge for it?
    It’s been something I’ve been curious about ever since seeing @Louis-DT-WR build his engine
    CalumC S 2 Replies Last reply
      @Stevie-Wonder Pretty sure he documented it all on this website...
        scrimsmustang
        @Stevie-Wonder said in 200cc crankcase conversion:
        It's nothing cases just need a couple of mm taking off to accept the 200 crankshaft. Any small local engineering shop will do it for around 30 quid. Top end just drops straight on
        • B Offline
          B Offline
          BEng1968
          Yes I know somebody who could do it, my dad. Where do you live?
          • B BEng1968
            @BEng1968
            What county/ town you at? It’d be nice to know a good engineer. They’ve all but disappeared down my way...
            Dorset
            • ChallengerC Offline
              ChallengerC Offline
              Challenger
              WR200 also uses bigger reeds, usual mod is to weld around the DTR reeds mount and then make the hole bigger for new reed cage
              • B Offline
                B Offline
                BEng1968
                Uk, Leicester
                • ChallengerC Challenger
                  Stevie Wonder
                  @Calum said in 200cc crankcase conversion:
                  Ye I know @Calum I’ve re-reading it but all the photos are now gone :(
                  @Challenger I’ve got a v force blaster 200 Reed cage that should help right ?
                  And thanks @scrimsmustang! If I’d been known it was simple earlier I think I’d have already done it 😂
                  Excusing the powervalve blade itself do you need the WR’s Servo motor, pulleys and housing etc
                  And I presume you need either a 200cdi or a Zeely/Ignitech programmable ignition too
                    markus.wM Offline
                    markus.wM Offline
                    @Stevie-Wonder "all the photos are now gone"
                    He changed his YouTube channel name when he built the cb750 but here's the link to his video which is a montage of all the photos of the conversion.
                    https://youtu.be/uVk7RZRvxDg
                      scrimsmustang
                      No you can use a 125 servo and a 125 CDI with no problems at all
