1.1k Posts 26 Posters 666.7k Views
    @Scootjockey
    It was proper sticky with black crud. Cleaned it up with some degreasant. I’ll have to keep my eye on it in the near future...
    Scootjockey
    I’d imagine that was due to carbon build up and the change in oil, just goes to show 2 strokes are fickle things and need regular TLC to be kept up to speed
    • S Scootjockey
      @Scootjockey
      Yeah. The engine seems to run fine (even good!) with the 2T synthetic oil I’ve been using. It’s only the power valve that’s suffering. Also I wasn’t sent the Oil I was expecting, I ended up with ‘Smith Alan’. I didn’t take any notice of the packaging, just that it was synthetic and approved. My embarrassing fuckup!...
      I’m going back to Castrol for the foreseeable future...
        @Scootjockey
        The power valve started sticking again a day after. I switched back to castrol R1 and it has cleared up nicely...
        The bike itself ran fine with the oil, it was just the power valve was gumming up with a thick, sticky varnish. Not power valve friendly! I still want to try Exol oil at some point...
          @SpookDog The bleed nipple should be backed off when retracting the pistons, you risk damaging something otherwise.
          On cars, with solid brake lines, the bleed nipple should be backed off else risking rupting a solid line.
          @Calum i once cracked a caliper not loosening the master cylinder cap not my finest moment
            Stripped and replaced the clutch side main oil seal. It looked fine, but on removal there was gear oil on the bottom of the main bearing. Brown, not red...
            Bike definitely feels different as well. The tick over has altered so I’m gonna have to tweak the airscrew, which I don’t think I’m very good at 🙄 The revs seem to pick up much ‘cleaner’ as well...
              Also replaced the EBC uprated clutch springs with the original ones, the clutch is as light as a feather!. Downshifting is a lot less clunky since I adjusted the basket/pressure plate 👍 ...
              Also my progressive springs have finally arrived and been posted! I really want a second hand set of forks to use either for the upgrade, or to use while the others are stripped for powder coating, ect...
                @SpookDog Oh awesome, I run the EBC Springs and after a short while of riding I don't bother with the clutch, just let off the throttle.
                The problem I was worried about was once you start increasing the vehicles power you may run into clutch troubles. But total overkill for stock systems.
                  My thinking was that an unrestricted motor might need uprated springs, but it seems absolutely fine with standard springs...
                  The HyperPro springs actually look like a top knotch product. I was a bit dubious at first, like I am with any fleabay listing, but they come with copious instructions, fork oil & fork grease for the bottom of the stantions that sit in the lower legs. Plus they are properly well packaged...
                  Made in 🇳🇱 Holland for 89 ~ 06 model Dtr/e’s, which was one of my worries 😜 ...
                    #293
                    Still haven’t fitted the new top & bottom bushes, new seals and progressive springs to the forks yet. I want to buy a used pair of forks to renovate and powder coat without taking my bike off the road...
                    Still waiting for Henrique Romeu to post my exhaust as well...
                    Waiting for some money to buy a new front tyre (Kenda 90-90 21in) to match the new rear 4.00 18 I already have brought...
                    My mongrel bike is still running really well at the moment, no head gasket issues 👍🤪 as soon as I get financially viable I’m gonna get a PJME rebore and maybe an oring conversion to the barrel. I am also going to rebuild another bottom end with new bearings all through. I have genuine crank seals, and am gonna get all koyo bearings with the best quality oil seals I can get for the rest of the bottom end. I’ve sourced another good condition crank (that I may get rebuilt with bearings and con rod if money willing)...
                    Swing arm and linkage bearings are all holding up since I replaced them 2 years ago, but I do want to replace them with koyo bearings and quality (if genuine seals can’t be found) seals because I got them from fleabay when I did the overhaul when I first got my basket case 🥴
                    I will get my shit together eventually 👻🐾🐾
                      Wish Me Luck
                      • Stevie WonderS
                        Stevie WonderS
                        Stevie Wonder
                        Best of luck! I’m looking forward to hearing a detailed explanation of how that Romeu pipe performs, I’ve been tempted myself and he’ll also do you a custom pipe spec’d for a WR200 with DTR mounts.
                        Also those kenda tyres are based of an old Dunlop design that would’ve originally come on some model DTR’s. They are highly regarded and going to be my next purchase for my other bike. I’ve not seen a better road / trail tire yet. Only a few contenders like the pirelli mt21’s or Dunlop d952’s
                          #296
                          @Stevie-Wonder
                          I’ll let you know when I get the pipe, with pics!...
                          I put Pirelli MT something (24?!) ‘rally cross’ tyres originally on my bike. They were total shite in my opinion! I don’t say that lightly, they were really uncomfortable on the road. It was like riding a pneumatic road drill 🤨 I had absolutely no confidence cornering with them on road. In fairness I think they were truly 50~50 orientated, so were to specific for my use. Also the rubber was a lot harder than the Kenda tyres I’ve gone through...
                            @Stevie-Wonder
                            Bollox! My rev count cable has broken! Can anyone point me towards a good replacement?...
                              Scootjockey
                              Anything on eBay cheap n cheerful, IMO. That goes for the speedo cable as well, As long as you oil them they should last as long as ye brake pads.
                              • S Scootjockey
                                Gutted! Finally found a set of forks complete with yokes and spindle on fleabay for a decent price £50 + 20 postage! And the bloke ‘won’t receive bids or offers’ from me! Meaning I can’t ‘buy it now’ even! 🤨
                                Only to me 😐 ...
                                  Only to me 😐 ...
                                  @SpookDog a lot of sellers only accept bids off buyers with good feedback. If you message him first he may sort it for you.
                                  S 2 Replies Last reply
                                    @markus-w
                                    I’ve got 100% feedback from a few hundred deals. I’m stumped...
                                      #302
                                      @markus-w
                                      I messaged him before, he’s not sure why I’m on the banned list, but is gonna look into it. I don’t have any clue as to what I might of done to deserve ‘banishment’ 😁 ...
                                      PS 4430 miles with no head gasket problem 😮
                                        @markus-w
                                        @SpookDog yes strange one bud. I've bought lots and lots of stuff off eBay but I've never sold anything so I guess I'd have no feedback? I'm not really sure how it works but I have seen ads saying basically people with no feedback don't bother.
                                          #304
                                          @markus-w
                                          I’ve never sold anything. Never thought about it before either. I had to go and look at my profile to find it. You press on your name banner at the top of ‘my eBay’ to find it...
                                          Mine was 205 not a few hunnies...
                                          PS edit. I remember seeing those kinda things about feedback, but not for a real long time...
