  3. Derestricting
  4. Derestrict yamaha dt 125 r 1997
66 Posts 5 Posters 28.0k Views
  • Mr ShadiM Offline
    Mr ShadiM Offline
    Mr Shadi
    Hello.
    I just bought myself a new Yamaha dt 125 r, and i want to derestrict it. But when i looked at the derestriction guide and then at my bike, the cdi wire colors were different. And I've been searching for a other guide to derestrict it but there is none.
    When I'm in the last gear the bike won't go over 80 km/h. If it goes i can hear the spark plug not getting spark and getting spark when its back at 80 km/h.
    If anyone could help me, it would be appreciated.
    markus.wM Mr ShadiM 2 Replies Last reply
    • Mr ShadiM Mr Shadi
      Hello.
      markus.wM Offline
      markus.wM Offline
      @Mr-Shadi what year is your bike?
      Mr ShadiM 1 Reply Last reply
        Sounds like reed switch to me...
          Mr ShadiM Offline
          Mr ShadiM Offline
          Mr Shadi
          @markus-w
          1997
          fcbb9b90-f903-45cf-a6ee-b25e92aafe12-image.png this one
            Mr ShadiM Offline
            Mr ShadiM Offline
            Mr Shadi
            @Calum how can i adjust it?
              Does sound like a rev limiter. Is anyone else getting frustrated with language barriers? šŸ˜µā€šŸ’«
              Need someone with better knowledge about the rev counter ā€˜bulb’ and more patience to explain than me, anyone?…
              Someone translate scrimstangs site, maybe?…
                @markus-w
                1997
                markus.wM Offline
                markus.wM Offline
                @Mr-Shadi the 1997 doesn't have the reed switch. It has a restricted CDI. Maybe change it for the older 3nc CDI. But you should be getting a lot more than 80kmh. Something else isn't right for sure.
                  Mr ShadiM Offline
                  Mr ShadiM Offline
                  Mr Shadi
                  @markus-w i can hear the spark plug not getting spark when it goes above 80 km/h. But it takes a a little while for it to start not getting spark (3 to 7 seconds). And when i disconnected one of three cdi wire connectors and went on the road to try again. The restrictor sound was different and started right after 80km/h with no delay, unlike if the connector was connected.
                    Hello.
                    Mr ShadiM Offline
                    Mr ShadiM Offline
                    Mr Shadi
                    @Mr-Shadi some pics
                    https://postimg.cc/14GSvH2d cdi
                    https://postimg.cc/KK3SBrtJ colors
                    https://postimg.cc/5Ycc3Y31 colors
                    https://postimg.cc/r05BYVn4 3 cdi wire connectors and 1 other
                    https://postimg.cc/5Q3ZbPMN voltage regulator
                      @Mr-Shadi some pics
                      Mr ShadiM Offline
                      Mr ShadiM Offline
                      Mr Shadi
                      @Mr-Shadi the model is 4BL
                      and its originally from Germany
                        @forum members
                        Isn’t there a later model that needs a CDI wire cutting & earthing somewhere? Or is that a Tzr?…
                        I’m sorry Mr-Shadi, I don’t know too much about later than 1995 model dtr125’s, other than what I have read. What country is your bike from? I’m guessing that english isn’t your first language?
                        I’ll do a bit of reading and try to find out about 1997 bikes…
                        Edit: 4dl Germany! Got it!
                          @forum members
                            The DTRE has a green and black wire, once earthed that's all the electrical restrictions and then the bike revs off the clocks.
                              I’m worried that he might have the one with the ā€˜silver box behind the 2T oil tank’ that needs loads of faffing about! I tried getting scrims guide up but kept getting a 401 error!…
                              CalumC Mr ShadiM 2 Replies Last reply
                                @SpookDog 401? That's Unauthorized
                                Right, yeah I don't know about that one. I only really researched the one for my bike.
                                Best thing to do is get a Zeeltronic ignition system for it and you're laughing.
                                S Mr ShadiM 2 Replies Last reply
                                  On a copy (of scrims) on another site it said to install an earlier CDI I think? Yamaha certainly had it in in for you lads with later bikes! Access Forbidden! šŸ˜› SNAFU! ā˜ ļø …
                                  My bad! It was 404 not quite as verboten! šŸ˜Ž …
                                    Yeah that makes more sense 404 - Not Found. I think you'll find 403 is Forbidden @SpookDog
                                      Mr ShadiM Offline
                                      Mr ShadiM Offline
                                      Mr Shadi
                                      @SpookDog i don't seem to have a silver box behind the oil tank. The only silverish/grayish box is the voltage regulator.
                                        Mr ShadiM Offline
                                        Mr ShadiM Offline
                                        Mr Shadi
                                        @SpookDog scrims sites hosting server has stopped broadcasting the info. But there is a slideshare link on the forum that has the site in slide form
                                          Mr ShadiM Offline
                                          Mr ShadiM Offline
                                          Mr Shadi
                                          @Mr-Shadi on the way back machine, its possible to see the old dt 125 net and other sites but not a lot of info on them
                                          With your input, this post could be even better šŸ’—
