1.1k Posts 26 Posters 639.5k Views
    I think you’re just addicted to titanium 😜 …
    @SpookDog Ordered a set of titanium studs this morning for my ETX this morning 🤣
    Listen, when it comes for OEM bonus points I'll admit, you can't beat that factory look. The issue I have, is none of my stuff is mint and the real art is doing a @scrimsmustang or @oldman build. The attention to detail for the OEM goodness is beyond anything I'll ever accomplish.
      #755
      I’m not an original’o’phobe myself, personally. I just think the OEM ones are better than aftermarket replacement ones. Not including titanium or stainless upgrades, which I would use if I weren’t so ‘broke a$$’ 🙃
      I do get people wanting originality on classic things, but I’ve always got the most out of doing my own thing. Cutting, welding/splicing and usually Matt black (cause of the broke ass thing 🙂) with the lettering on the tyres picked out in white (child of the 70’s!)…
      PS! Do the clutch springs need upgrading with an Athena kit? Or is standard fine?…
      S MadGyverM 2 Replies Last reply
        Got the bottom end pinned together, despite the wind which always blows crap about when I’m doing engine internals! I put up a beach umbrella and hid behind it.
        It went together well, this is my third bottom end rebuild and I like to think I’ve improved a bit each time 🙂 The new crank spins real easy, you could blow on it and spool it up!…
          I'm not going to lie, you use your bike a damn sight more than I use any of mine! I mostly cycle/run everywhere.
          No you don't need clutch springs for the Athena 170 kit, so long as your clutch is healthy you should be fine. That said, I run the stiffer spring setup, along with the EBC Dirt clutch plates.
          Been out on my DT today and it is running CRISP in this weather. Really hurtles along!
          Yeah it's satisfying riding the bike with a motor you've put together.
            MadGyverM
            MadGyverM
            I understand you so much and I am in your "broke a$$" team as well (but 80s child).
            • S
              Didn’t get owt done today. Bike was running properly crisp tho! It was like the cold dense air was a nitrous hit for the old bee~atch! The bits & bobs motor I’ve got in at the moment has done me reall, really well considering the absolute state of it! I’m just coming up on 30,000miles since I got and built the bike & engine!…
              All the hassles I’ve had and IT has never left me stranded on the side of the road. Bless!!…
              I’m quite looking forward to the new chapter in Its incarnation . I’m hoping it’ll run like a dream from here on out 😜
                I seriously can't get over how much you ride lmao. I don't think I've done 30k miles in all of the vehicles I've owned.
                  I still need a gudgeon pin for an Athena 170 piston. It’s 16mm x 56mm. The only one I can find is 16 x 57mm…
                  If anyone has put a new piston in their Athena kit and still has the old pin please let me know. I can’t do any more to my build till I get one 😐 …
                  Cheers Peeps!…
                  CalumC MadGyverM 2 Replies Last reply
                    Cheers Peeps!…
                    @SpookDog I only recently threw away an Athena 170 gudgeon pin that only saw a few hundred miles on it 😮
                      Cheers Peeps!…
                      MadGyverM
                      MadGyverM
                      Cheers Peeps!…
                      Why don't you take the 16x57 and machine off 0.5mm from each side?
                      I remember the pin from the kit has a little play when installed with the circlips,maybe there is space for that 1mm.
                        #764
                        Well f@nk you very much! Wasteful Torrie! 🙂 …
                        @MadGyver
                        My plan B! 😜 …
                        I’ve got one ordered earlier today, once I found out my siss’s card worked. She’s a fuxin heroin when it comes to keeping me afloat!
                        It looks like there is enough room to fit the 57mm pin, I’m just not clued up on heat expansion & the like. I can just imagine it popping off a curclip when it comes up to temp! 🫤 …
                        Edit: I forgot to ask about Athena replacement piston rings. Best place to get them? I understand that they’re specific to these kits as they’re 1mm thick/thin? Seems churlish not to fit new ones if they’re available and not astronomicaly priced …
                          @MadGyver
                          My plan B! 😜 …
                          The spacer that I have on the primary drive side of the crank has a groove machined into it. Does the groove side go into the crank seal?…
                          The others I’ve done before haven’t had the groove…
                          • MadGyverM
                            MadGyverM
                            #766
                            Can you post a picture,I don't remember groove on mine.
                            • MadGyverM MadGyver
                              #767
                              @MadGyver
                              You can see that it’s been used either way round. I was just wondering what the reason is? If it aligned with the seal I could understand, but the wear pattern shows it doesn’t…
                              Actually, saying that! It looks like they’re not symmetrical! Strange! 🤔
                                @MadGyver
                                #768
                                Now I’m wondering if it’s original to the Dtr? It looks like it was used in a different engine, from the wear on one side to the other!
                                I don’t have another one kicking around that I know of. I’d like to know the measurements of a proper one so I can compare. It did skim off a sliver of the seal when I tapped it in. I though it was because it was a NOS seal and a bit hard. Guess I could of been wrong…
                                Edit: then again someone could of just tapped the seal in too far, or not enough one of the times! Arrggghhhhh!!! 🤪
                                  #769
                                  Oh well, one thing that I can say with absolute conviction is: don’t buy new old stock seals trying to save money! 😉
                                  A 35 year old seal in the bike, is worth many, many more than in the bush. They age better in their natural environment 👍 …
                                  • MadGyverM
                                    MadGyverM
                                    #770
                                    There is no reason for that groove there,no gain in lubrication or anything else. It's a spacer for seals. It must be from a wornout seal.
                                    I had something similar on the spacer that seats the seal at the external chain sprocket. It looked like factory groove.
                                      #771
                                      @MadGyver
                                      Sorry bud, I disagree. I know, and have had, what you’re talking about. This isn’t wear, it’s machined. It’s a perfect V.
                                      It’s just 1 not 2 like ‘normal’ wear would be?
                                      With the new (nitrile?) seal in place flush with the casing the groove lines up with the outer lip. I think it actually gives a lot more surface area for the outer lip of the seal to mate up to…
                                      I’ve only had the wear line on single lip seals, the sprocket spacer has been my experience as well. Now I’m wondering!…
                                      I just can’t get over the amount of ‘curve balls’ this bike has given me! The learning curve has been like climbing K2! 😳
                                      I do appreciate the input though, please let me know your thoughts!…
                                        @MadGyver
                                        @SpookDog I suspect there may be a correct way to put it in.
                                        Part Number 25.
                                        Can get a new one in Titanium 😉
                                        https://titanclassics.com/product/titanium-front-sprocket-spacer/
                                        • D
                                          It's a wear groove, seen it many times on cranks etc. your lucky on the DT it's a removable bush/sleeve, that can be replaced. I'd turn it so the seal is running on a smooth section of the sleeve.
