1.1k Posts 26 Posters 671.6k Views
    @MadGyver
    Yeah, I’ve been told that the PV signal wire is black and yellow. I didn’t look that closely for colour when I was putting the loom, CDI and stuff all together.
    The wire from my servo is black & white striped. So I’ve been wiring it to the bikes kill switch curcuit. Fux knows how it was still working and kicking in the power valve when revving the engine. I never checked the RPM speed, just that the valve was operating when revved…
    So tomorrow I go for a test ride with it connected yellow to white and opening at 6k~ish…
    It’s strange that the kill switch curcuit on the loom is black&yellow, not white. It does look like the wire may of been replaced before, now with hindsight, I’ve scrutinised it!…
    The power valve has been opening at just below 4K RPM which is about 1/8 throttle. If I’m right, this would impact the pilot/throttle-valve curcuit causing it to ‘snaggle’ maybe because of the change of scavenging?
    Remember, I’m trying to suss this out from a position of total ignorance! Any thoughts or feedback would be appreciated…
    PS When I put my chain back on after spraying the frame, ect. I think I may of put it on upside down (or inside out). It’s been getting tighter day by day. I’ve loosened it once but it’s tight again. No slippage at the rear spindle/adjusters. I thought maybe the salt had gotten to it because I’ve done fux all miles in the last month or so (120) Thoughts again?…
    #977
    So much better! There’s a little bit of cleaning up to do, from where I was adjusting the airscrew to try and fix the issues before…
    I’m going to wait for a decent wind free & dry day to do that though…
      #978
      Cue tumbleweed!…
      Still waiting on a good wind & weather ‘free’ day to check, adjust the airscrew…
        @SpookDog Just been chewing this over a bit more and the orange wire from the CDI energises the low-tension side of the coil (which then goes to earth). Your wiring loom is also on the opposite side of the frame to where it should be which means the CDI wires and the main loom are being forced together, potentially allowing the pulse from the CDI to track to the oil light wire at certain engine speeds (30-year-old wiring and all that). So I'd definitely be having a good poke around in this general area, and looking again at the cable routing images I posted up on here a few weeks ago.
        TBH although I understand wiring diagrams, due to my liking for keeping cable routing stock and well coated with WD40 I don't have a huge amount of experience at actually solving electrical problems but if your wiring is incorrectly routed I'd definitely be starting here.
        #979
        Just a quick thank yous. My radiator level has been sweet since installing the banjo union U 👍 …
        Bike is running @ 90%, best yet but still a little snaggle at low rpm cruising. Leaning out the airscrew has improved but not cured it.
        Just replaced the reed valve and re-installed the plastic ‘pickup’ tube on the pilot jet. Just going dotty for T and crossing my I’s at the moment. Will test ride tomorrow weather permitting.
        If it’s still the same I’ll change over the CDI unit, Dog only knows what damage having the yellow & white stripe wires crossed has caused?!…
          @SpookDog All sounds good!
          If the bike still runs I doubt you've done any damage to the CDI by crossing those wires, usually CDI units either work or they don't. Interesting it did still work though; the black/yellow wire tells the little on-board computer inside the 3-wire servo the engine speed (like the crank sensor on a car) and the black/white wire stops the plug sparking by earthing the CDI when you flick the kill switch or turn off the ignition, so I guess if you hooked either of those wires from the CDI up to some test equipment like an oscilloscope, you'd probably get some quite similar results.
          Keep us posted for any improvements!
          S 2 Replies Last reply
            #981
            Thing that blew my mind was that it opened at around 4K! Why would the resistance (I’m guessing) change on the ‘to earth’ kill curcuit?! Also the chances of getting a 3 wire servo with a black/white stripe? As well as the black/white wire from the loom being changed?! That’s some fuxin cosmic improbability going on. Whiskey Tango Foxtrot is going on with My Life?!…
            I’ll take some pics when the light is good enough to show the colours properly…
            Couldn’t make this shit up!…
              #982
              Could it possibly be something as banal as a rotten earth to the coil?
              It seems it may be that the opposite side to the orange wires earth point (on the coil!) is more important that it’s connected 100% to the loom, rather than the frame…
              There is a join in the earth lead from previous abusers. One of those hard plastic crimp jobs. If I’d thought it was essential I’d of looked and addressed it before now! The wire was dry and crumbly between fingers…
              Will know tomorrow when I’m alcohol free, but the motor is spooling up really crisp and fast, and the spark seems a lot stronger. I’ve been wrong before though…
                #983
                Still not there, my spark is healthier looking, but still red-orange. I believe a healthy spark should be blue-white?…
                PS earth is NOT that important, it still runs with it disconnected 😐
                S MadGyverM 2 Replies Last reply
                  #984
                  I tried fitting the 3nc CDI, it only fires once then nothing. It has 3 extra wires on it, blue and sky blue (2pin block connector) and blue/yellow-stripe (maybe white) I’m wondering if they’re to do with the side stand kill curcuit. I think I need to manipulate them to make it spark constantly…
                  Will the bike start with the side stand down and in neutral? Or does the stand have to be up regardless?…
                    MadGyverM
                    MadGyverM
                    I think you are slowly slipping into my Gordian knot electrical problem.
                    • MadGyverM MadGyver
                      #986
                      @MadGyver
                      Yeah, I don’t give up easily though. 35 year old looms with black tarnished copper cores can be challenging! This has only started since I removed, stored and replaced the loom. It’s easy to find an intermittent broken inner if it’s just an indicator or tail light wire that you can wobble around. Wires in the core of the loom are another matter
                      Have you done anything on your bike lately? I know that the weather is still shitty here most of the time…
                      You’ll have to update your thread with the current situation when you can. We’ll get them running again like they should…
                      MadGyverM 1 Reply Last reply
                        I feel quite blessed really compared to your situation @SpookDog , I got my DT off a older gentleman at 5500 miles and have had it since. It's been nicked in that time but luckily that was just indicators that I binned off anyway. Your problems sound like what I am going to have with my ETX. That thing is pure trash
                          #988
                          Fux u very much 🙂 ..
                          I can only afford things that other people have trashed 😜 …
                            @MadGyver
                            MadGyverM
                            MadGyverM
                            @MadGyver
                            I understand,opened twice the 30 year loom completely,once when rebuilding and now when searching for the electrical problems.Second time was 3 times the searching test&time of the first.I believe now is almost new.
                            I haven't done much because the bad weather most of the time,no light to work after sunset,2 small kids so almost no spare time and my health problem.
                            I hope so,need so much to ride again it's like a dream for me now.
                              #990
                              I’ve found the 2 wires that the starter solenoid joins to the loom by, also a wire that appears to be the clutch switch.
                              What stator did these 3mb RE’s use bud, any idea?…
                              Edit: I managed to get the 3nc CDI working thanks to HotShots 3mb wiring diagram. Turns out that the wire that goes to the side stand, from the CDI, needed earthing…
                              Will test it out later when I can…
                              PS if this doesn’t cure it I’ll have to try swapping out the carb for the tzr one or my old one. I’m wondering if the choke plunger rubber is worn and not sealing properly.
                              Also the ignition coil on the stator and the wiring between it and the CDI unit…
                              I can’t think of anything else at the moment…
                              Still getting light missing at low revs and an orange/red spark…
                              I replaced the connector & wiring from pickup to CDI. Repaired a connection & wiring in the orange coil wire as well.
                                #991
                                @Me!…
                                It would appear that a hot wired £25 CDI unit bought from fleabay has cured the low rpm problems! 25 miles with no noticeable pops or hesitation! I’ll check again tomorrow after I’ve adjusted the new slack in my chain…
                                But for the time being I am optimistic!…
                                  @Me!…
                                  #992
                                  Last post of the day!…
                                  Sparks?! I believe that they should be fat blue~white, yes? If mine are orange ~red then I’m wondering if the capacitors in the CDI unit are getting enough electrickery to generate constant good blue ~white sparks? Even if this could contribute to the demise of a CDI unit? (Serious Deja Vu here somehow)
                                  I’m thinking of changing out the ignition ~source coil and the wiring from the stator to the CDI unit anyways...
                                  I would seriously love some feedback about spark colour and strength…
                                  • MadGyverM
                                    MadGyverM
                                    Healthy spark is blue-white color.
                                    You are dangerously close to my path...
                                      #994
                                      @MadGyver
                                      Bikes still running good and sweet. The source coil was well in spec with the Ohms (not the purple ones)
                                      One good thing is I’ve learned how to isolate the ignition system from the rest of the loom. Just pulling the black/white wire (kill switch & key barrel) on the CDI isolates most of it. Depending on the CDI year there’s more you can do to isolate the side stand curcuit. It doesn’t use a ‘to earth’ curcuit to kill the engine. It uses a curcuit that kills the ignition if not earthed (IE a partial break inside the insulation will kill it) You can bypass the loom by earthing the single blue CDI wire to the HT earth point.
                                      Both these give you a chance to identify a possible partial/intermittent break in the loom…
                                      I’ll read through your thread again. You have a 3nc CDI if I remember?
                                      • MadGyverM
                                        MadGyverM
                                        @SpookDog Yes you remember correct,1x3NC and 2x4DL.
                                        I did some work on the DT,will update the thread within the week.
                                          @MadGyver
                                          Let me know what is happening with the spark! If it’s sparking and not running, or if there is a spark but the engine only fires once. Or there’s no spark at all. We’ll get your bike running bud, I’d stake my ‘reputation’ on it! ROTFFLMAO! 😜 …
                                          My bikes still running and firing smoothly, I’m almost ready to call it fixed!…
