  4. crank noise
crank noise
15 Posts 4 Posters 2.6k Views
    PJME is your friend. Make sure you get the right clearances as well. C3 IIRC.
    Yamaha DT125R Crankshaft Main Bearing LH
    Yamaha DT125R Crankshaft Main Bearing RH
    I always replace all other gearbox bearings whilst you're there, but that's just me and my OCD.
    E 1 Reply Last reply
      E Offline
      E Offline
      erioni123
      @Calum is there any way to split the cases without a case splitter as someone said that you can but i dont think you can
        I've never used a case splitter. What is a case splitter?
          E Offline
          E Offline
          erioni123
          @Calumhow do i split the case tho, the cank case how do i split it apart to change the bearings
            Undo the bolts, dismantle the clutch/generator and then gently tap the casings apart. I use a rubber mallet.
              E Offline
              E Offline
              erioni123
              @Calum how do you tap them apart like there is no place to hit it
                There is a spot where the starter motor goes. And there is a piece up top near the inlet manifold.
                It literally only needs a gentle tap.
                The other good technique is just use the flywheel puller. These can be had on eBay for next to nothing and can even be made from scrap metal. It's well described in the Haynes.
                • E erioni123
                  @erioni123
                  I don’t mean to offend.
                  Are you sure you’re up for this? Is this the first engine that you’ve worked on?
                  There are certain tools you need to dismantle the engine. Not to mention the damage you can do trying to remove bearings, even after you’ve successfully dismantled the casing…
                    @erioni123
                    E Offline
                    E Offline
                    erioni123
                    @SpookDog its my first time splitting cases but im not sure if i will do it myself maybe i'll have someone do the rest of the work just to be safer, but i saw that people use case spliters its a tool made for spliting them
                    • E erioni123
                      @erioni123
                      Like Callum said, use a flywheel puller to push the crank in and separate the cases. DO NOT use a screwdriver or chisel, please!…
                      A rubber mallet is usually enough for me…
