  4. Head scratcher
Head scratcher
30 Posts 4 Posters 8.7k Views
  • StanKnS StanKn
    Yeah I know, I thought they might be bad. I'll check my valve tomorrow. Is there anyway to check the seals.
    @StanKn
    Have you checked the wire for breakage?
    • StanKnS
      StanKnS
      StanKn
      What sort of wiring issue could it be? My power valve is opening all the way when running. Took if for a drive with the cover off and downshifting to get it up to around 8000 and valve opened all the way. Could their be and ignition timing issue?
      • StanKnS StanKn
        @StanKn
        The ‘derestrict’ wire…
        • StanKnS
          StanKnS
          StanKn
          Tried that too, reconnected it no difference. I'm leaning towards to cranks seals being gone?
          • StanKnS
            StanKnS
            StanKn
            It's so weird to me, it will rev up just fine at neutral. It struggles in first and then gradually gets worse and worse as more load gets put on the engine
              That's what it sounds like to me. The more load part makes sense.
              You're not running any aftermarket "racing" coil are you? I had this with this knock-off Chinese racing coil that had me scratching my head for ages!
              • StanKnS StanKn
                @StanKn
                If there’s a break inside you won’t tell by reconnecting it. It’d be the same
                What colour is the plug?
                Is the spark good?
                If you can’t dial in on the problem you’ll have to do a top end check eventually. Head off or at least check out the piston and rings through the exhaust port…
                • StanKnS
                  StanKnS
                  StanKn
                  I've rebuilt the top end, checked the ring gap all perfect new gudgeon pin and bearing too, it's running a brand new genuine yamaha coil right now. Is their any way of checking for a break with multimeter all the wires. Spark is perfect, but plug always comes out a little oily and black
                  • StanKnS
                    StanKnS
                    StanKn
                    *all the wires seem okay on a visual inspection
                    • StanKnS StanKn
                      @StanKn
                      Oily and black is rich mixture. Probably where you’ve played with the needle/carb settings…
                      You won’t see a break inside the insulation.
                      I don’t know much about your model but it sounds like it’s rev limiting itself. If the wire (green?) isn’t properly earthed, or connected to it’s proper place (CDI?) the CDI might be defaulting to a ‘safe’ mode. I’ve heard of similar problems with bikes with the rev limiter read bulb in the speedometer…
                      It’s the only thing I can think of if everything else is in good order like you said. It started off intermittent then failed completely…
                      You can do continuity testing with a multimeter. You may have to pierce the wire with a pin to make a testing point…
                      • StanKnS
                        StanKnS
                        StanKn
                        Interesting, I've got it running leaner now and it's a a fraction better but still doesnt rev under load.
                        What do you mean by rev limiter read bulbs? I'll do a bit more Inspecting today.
                        Thanks for all the help. It's greatly appreciated.
                        • StanKnS StanKn
                          @StanKn
                          Hey! Try running it with the ‘deristrict’ wire not earthed. See if there’s any difference…
                          The reed/read bulb refers to a dtr (don’t know what year) rev limiter…
                          PS have you cleaned out the jets and emulsion tube when you had the carb apart?…
                          • StanKnS
                            StanKnS
                            StanKn
                            I've cleaned all the jets, but was wondering the emulsion tube refers to the press put large jet, that the main jet screws into, does that have some small holes going up the sides, I've only ever sprayed it with compressed air I've never removed it perhaps they may be blocked if they are present. I reconnected the wire yesterday and it made zero difference, I'll have a look to see if I have that read bulb. Thanks again @SpookDog
                            • StanKnS
                              StanKnS
                              StanKn
                              If it helps @SpookDog my CDI is marked 5AN 72P
                              • StanKnS
                                StanKnS
                                StanKn
                                Hope this image works, just found this could be an issue?
                                link text
                                • StanKnS StanKn
                                  @StanKn The emulsion tube is the long brass tube the main jet screws into yes. If you haven't done this yet you'll need to get this out (screw the main jet back in without the brass washer and lightly tap it), make sure all the holes in the tube are unblocked and also check its air feed is clear, this is the small clear tube which pushes onto a brass tube on the right of the carb body just in front of the carb-to-airbox rubber (it's a very small hole and difficult to blow through).
                                  What happens over time is the space between the carb body and emulsion tube accumulates moisture and debris and this blocks more and more of the holes until it just starts fourstroking one day.
                                  • StanKnS
                                    StanKnS
                                    StanKn
                                    Christ, I thought it was just a big brass tube since there was no easy looking way to get it out. Feel a bit silly now ahah.
                                    • StanKnS StanKn
                                      CDI doesn’t look right. I’ve never seen one with blue shrink insulation…
                                        @SpookDog I wouldn't get excited about the shrink wrap, it's not a DTR after all.
                                        https://motorradteilehannover.de/Yamaha-TDR-125-5AN-Bj-1997-control-unit-CDI-control-part-A3999
                                        Does look very similar to a DTRE ignition system though. Zeeltronic might be a good upgrade to the TDR ignition system.
                                        • StanKnS
                                          StanKnS
                                          StanKn
                                          Thanks again lads. Yeah I'm definitely going to get the zeeltronic in the future maybe this a sign to get it now
