  4. Head scratcher
Head scratcher
30 Posts 4 Posters 8.7k Views
  • StanKnS
    StanKnS
    StanKn
    It's so weird to me, it will rev up just fine at neutral. It struggles in first and then gradually gets worse and worse as more load gets put on the engine
      That's what it sounds like to me. The more load part makes sense.
      You're not running any aftermarket "racing" coil are you? I had this with this knock-off Chinese racing coil that had me scratching my head for ages!
      • StanKnS StanKn
        @StanKn
        If there’s a break inside you won’t tell by reconnecting it. It’d be the same
        What colour is the plug?
        Is the spark good?
        If you can’t dial in on the problem you’ll have to do a top end check eventually. Head off or at least check out the piston and rings through the exhaust port…
        • StanKnS
          StanKnS
          StanKn
          I've rebuilt the top end, checked the ring gap all perfect new gudgeon pin and bearing too, it's running a brand new genuine yamaha coil right now. Is their any way of checking for a break with multimeter all the wires. Spark is perfect, but plug always comes out a little oily and black
          • StanKnS
            StanKnS
            StanKn
            *all the wires seem okay on a visual inspection
            • StanKnS StanKn
              @StanKn
              Oily and black is rich mixture. Probably where you’ve played with the needle/carb settings…
              You won’t see a break inside the insulation.
              I don’t know much about your model but it sounds like it’s rev limiting itself. If the wire (green?) isn’t properly earthed, or connected to it’s proper place (CDI?) the CDI might be defaulting to a ‘safe’ mode. I’ve heard of similar problems with bikes with the rev limiter read bulb in the speedometer…
              It’s the only thing I can think of if everything else is in good order like you said. It started off intermittent then failed completely…
              You can do continuity testing with a multimeter. You may have to pierce the wire with a pin to make a testing point…
              • StanKnS
                StanKnS
                StanKn
                Interesting, I've got it running leaner now and it's a a fraction better but still doesnt rev under load.
                What do you mean by rev limiter read bulbs? I'll do a bit more Inspecting today.
                Thanks for all the help. It's greatly appreciated.
                • StanKnS StanKn
                  @StanKn
                  Hey! Try running it with the ‘deristrict’ wire not earthed. See if there’s any difference…
                  The reed/read bulb refers to a dtr (don’t know what year) rev limiter…
                  PS have you cleaned out the jets and emulsion tube when you had the carb apart?…
                  • StanKnS
                    StanKnS
                    StanKn
                    I've cleaned all the jets, but was wondering the emulsion tube refers to the press put large jet, that the main jet screws into, does that have some small holes going up the sides, I've only ever sprayed it with compressed air I've never removed it perhaps they may be blocked if they are present. I reconnected the wire yesterday and it made zero difference, I'll have a look to see if I have that read bulb. Thanks again @SpookDog
                    • StanKnS
                      StanKnS
                      StanKn
                      If it helps @SpookDog my CDI is marked 5AN 72P
                      • StanKnS
                        StanKnS
                        StanKn
                        Hope this image works, just found this could be an issue?
                        link text
                        • StanKnS StanKn
                          @StanKn The emulsion tube is the long brass tube the main jet screws into yes. If you haven't done this yet you'll need to get this out (screw the main jet back in without the brass washer and lightly tap it), make sure all the holes in the tube are unblocked and also check its air feed is clear, this is the small clear tube which pushes onto a brass tube on the right of the carb body just in front of the carb-to-airbox rubber (it's a very small hole and difficult to blow through).
                          What happens over time is the space between the carb body and emulsion tube accumulates moisture and debris and this blocks more and more of the holes until it just starts fourstroking one day.
                          • StanKnS
                            StanKnS
                            StanKn
                            Christ, I thought it was just a big brass tube since there was no easy looking way to get it out. Feel a bit silly now ahah.
                            • StanKnS StanKn
                              CDI doesn’t look right. I’ve never seen one with blue shrink insulation…
                                @SpookDog I wouldn't get excited about the shrink wrap, it's not a DTR after all.
                                https://motorradteilehannover.de/Yamaha-TDR-125-5AN-Bj-1997-control-unit-CDI-control-part-A3999
                                Does look very similar to a DTRE ignition system though. Zeeltronic might be a good upgrade to the TDR ignition system.
                                • StanKnS
                                  StanKnS
                                  StanKn
                                  Thanks again lads. Yeah I'm definitely going to get the zeeltronic in the future maybe this a sign to get it now
                                    #26
                                    Wasn’t just the wrap. It was the gap in the resin around the wires. But yeah, I have no experience with later bikes 🙂 RE was a boring class I had to sit through when I was 10 years old…
                                    I hope you find the problem…
                                    • StanKnS
                                      StanKnS
                                      StanKn
                                      Thanks for all the input and advice. I'll try it all 🤣. I hope so too @SpookDog. Thanks for all the help again really appreciate it
                                      • StanKnS
                                        StanKnS
                                        StanKn
                                        @HOTSHOT-III thanks mate you were write , feel like such an arse currently there's was around 10 years of crud in the emulsion tube. I overthinked like mad feels a bit silly hahaha. She's is running a real treat took awhile to get the tube out not sure its even been out before
                                        • StanKnS StanKn
                                          @StanKn No worries bud, lots of people miss this the 1st time they do a carb strip on these bikes. Glad to hear it's running better now!
