  3. Suspension
  4. DT125X need help with fork(resolved)
12 Posts 6 Posters 4.6k Views 1 Watching
  • H Offline
    H Offline
    HOBO4LIFE
    wrote on last edited by HOBO4LIFE
    My fork is totally gone, beyond repair. I was wondering what other forks can I fit without much work.
    • A Offline
      A Offline
      AndyYam
      Why do you want other forks? Just stick another set of originals in.
      • H Offline
        H Offline
        HOBO4LIFE
        If I could find any
          I am pretty sure those forks are so so so common used on loads of bikes. I just went to a scrap yard and found ones I needed.
          H 1 Reply Last reply
            H Offline
            H Offline
            HOBO4LIFE
            @Calum So are dt125re forks same?
            DartyD 1 Reply Last reply
            • H HOBO4LIFE
              DartyD Offline
              DartyD Offline
              @HOBO4LIFE Yes,
              Also Yamaha WR125R forks are a straight swap and a little better on rebound than DT forks.
                @HOBO4LIFE Yes,
                H Offline
                H Offline
                HOBO4LIFE
                @Darty What about WR125X forks, will the calliper fit without adapter?
                N 1 Reply Last reply
                • H HOBO4LIFE
                  N Offline
                  N Offline
                  @HOBO4LIFE If the fork brackets and disc sizes are the same then yes, you should be OK. The DTX, DTRE and WR all had a 298mm front disc, so in all probability they are most likely all the same units, with maybe some minor differences. Compare pictures and ask for bolt spacings and disc sizes etc. before buying, just to double check and be sure.
                  Most bike manufacturers are notourious for using parts off an older bike, albeit with some upgrades such as stiffer springs etc. when releasing new models. As it costs them a hell of a lot more to design from scratch, rather than upgrading existing parts from current bikes. As the saying goes " If it ain't broke, then why bother fixing it". 😉
                  • H Offline
                    H Offline
                    HOBO4LIFE
                    Sorry for late reply and bringing old thread back up.
                    WR125X forks do fit, but you will need wr125x calliper because holes do not match, washers on one side and modify the speedo drive(wr125x doesn't fit as its electronic).
                    3
                    • H HOBO4LIFE
                      N Offline
                      N Offline
                      @HOBO4LIFE Cool - Good to know!!! 👍
                      • GoProKid95G Offline
                        GoProKid95G Offline
                        GoProKid95
                        Aren't the WR125 forks slightly shorter? I tested a set, however may have been the supermoto's on my DT and I felt like the bike was leaning forward more than it was usually? 😞
                        GoProKid95
                        2006 DT125RE - SM Conversion
                        • GoProKid95G GoProKid95
                          H Offline
                          H Offline
                          HOBO4LIFE
                          @GoProKid95 I am not really sure, as my dt forks were garbage all the time.
