  4. Project I can't leave things alone!
56 Posts 6 Posters 21.9k Views 2 Watching
  • MightymanM
    My vapor clocks came with a set of mounts that allowed you to put it into any normal sized set of handle bars so if you mention you'll be fitting it to a yz 125-ish bike, they may give you the same mounts.
      wrote on last edited by Darty
      @gareth_iowc Sweeeeet. Dream project, those 86/87' YZ125 engines are a funny engine, think they were rated at 24hp?
      You could expect to see 9-10 more HP and substantial torque with your 98' engine.
      What are the dimensions for your bearing cup? Alot of people looking at fork upgrades
        @Darty My sketches should be uploaded here. But then they were for a probably odd forks
        • G
          G
          gareth_iowc
          Evening all,
          Follow @Calum guide - https://dt125r.co.uk/topic/17/usd-conversion-bearing-cup-method
          I don't know the measurements off hand as the machine guy did it. It was dam close was only a millimetre or so out..... well that's what he told me.
          Calum's guide is great just take that with your yz forks, new yz top bearing, new dt bottom bearing and the frame to a local machine shop and they should work some magic no problems at all.
          One interesting think was the stops on the yz are on front centre of the fame and the dt has two rear ones. Luckily it gives the correct steering angles with no modification 😆 Winner.
          Little update today the yz 125 rear swing arm turned up today. Would have been great but it doesn't fit.
          I was surprised to find it's not as wide as the original dt one at the frame. It was only cheap and I didn't think it would fit with out some modifications but as it's smaller I'm going to scrap that idea.
          I would like the dt200 one was it Calum? But I can't find one for sale in the uk and for a good price.
          DT125R 2000
          DRZ400 2006
          Golf Mk3 20v Turbo 1996
          • G
            G
            gareth_iowc
            @Darty yeah I'm going to use the 98 as it's closer to the bikes year. Started it finally today as well sounded great. Ears are still ringing.
            The 1lx will be up for sale with 0 running hours fresh rebuild. I thought that was 33bhp as well? I'll have to have another look on the net.
            DT125R 2000
            DRZ400 2006
            • G gareth_iowc
              @gareth_iowc Is the YZ engine a straight swap with no or minor mods required then???
              • G
                G
                gareth_iowc
                Yeah fits but needs a few modifications. Needs custom head to frame brackets and the front engine brackets.
                The decider was the fitment between the swingarm and that fits no modifications 😃
                DT125R 2000
                DRZ400 2006
                • G
                  G
                  gareth_iowc
                  So the yz rear wheel turn up today 😄
                  It's 19 inch rather than the stock 18 inch dt wheel.
                  Looks like it's going to work great only thing I've noticed so far is the yz spindle is larger than the dt.
                  The calliper carry will need a little adjustment to make the new spindle fit.
                  DT125R 2000
                  DRZ400 2006
                  • G gareth_iowc
                    @gareth_iowc Nice fat rubber you have their bud - looking good so far!!! 👍
                    • G
                      G
                      gareth_iowc
                      Got the new bolt for the dog bone to mount it to the frame from fowlers 🙂
                      Just waiting for the rear axle spindle to turn up so I can get the rear wheel fitted 🙂
                      DT125R 2000
                      DRZ400 2006
                      • G
                        G
                        gareth_iowc
                        Doh!! So the yz spindle is a lot shorter than the dt. So the next thing to try will be to see if I can take the dt wheel hub and fit it in the yz wheel with the yz spokes.
                        Thoughts?
                        DT125R 2000
                        DRZ400 2006
                        • G gareth_iowc
                          Thoughts?
                          @gareth_iowc This dude runs a wheel rebuilding service and has a good rep;
                          https://www.facebook.com/paul.ritson.9?hc_ref=SEARCH
                          • G
                            G
                            gareth_iowc
                            Thanks 🙂 only problem is I don't have Facebook lol.
                            Might try a local bike shop as I've been told it's quite involved with getting it right.
                            DT125R 2000
                            DRZ400 2006
                            NINJAN CalumC 2 Replies Last reply
                            • G gareth_iowc
                              @gareth_iowc No Facebook??? Dude your missing out. There are some wheel builders on ebay too.
                              • G gareth_iowc
                                @gareth_iowc Yeah wheel building is a dark art, so I am told.
                                • G
                                  G
                                  gareth_iowc
                                  Haven't posted in a while but things are still slowly moving .
                                  The wheel has been with the builder for a week now so hoping to have it back soon.
                                  Ordered the wrong front yz calliper doh!! So sending that back and ordering another. They calliper carry is wider on a 98 then the 97. My forks are 98 🙃.
                                  The yz exhaust has arrived as well but I forgot to take a photo. It doesn't quite fit might need a little bit of heat and some bending to make it work but it's not to far off.
                                  DT125R 2000
                                  DRZ400 2006
                                  • G gareth_iowc
                                    @gareth_iowc Took 6 months for the wheel builder to build my brothers YZ wheels!!!
                                    • G
                                      G
                                      gareth_iowc
                                      Jesus 6 months! He's going to have them ready by end of next week 🙂
                                      DT125R 2000
                                      DRZ400 2006
                                      • G gareth_iowc
                                        @gareth_iowc Nice big knobs - LOL 😉
                                        • G
                                          G
                                          gareth_iowc
                                          Yeah not sure what it's going to be like on road in the wet haha.
                                          DT125R 2000
                                          DRZ400 2006
