  3. Health Check
Health Check
28 Posts 8 Posters 9.8k Views
    @Bentley The expression if it ain't broke don't fix it always springs to mind.
    Trust me when I say if the engine needs a rebuild, it'll tell you long before you need to.
    Clues will be obvious, excessive smoke, down on power and it'll sound like there is sand in the engine.
    B
    B
    Bentley
    @Calum ok Calum. Your a very knowledgeable chap so I'll take your advice. I'll change the tranny oil it's 10w40 for these isn't it? I'm thinking Castrol? I do have some purloined but that's heavy gear oil
    • B
      B
      Bentley
      I've just seen I've got a 3MB00 cylinder is that the standard for the Re?
      • B Bentley
        @Bentley http://www.eurocarparts.com/ecp/p/car-accessories/engine-oils-and-car-fluids/engineoils/15w40-engine-oil/?521771961&0&cc5_246&gclid=CL6Awo_niNMCFYY-GwodnAIC6w
        A litre of that stuff will work fine.
        AVOID MAGNETEC oil. It'll make your clutch slip like a bastard lmao.
        It does depend on how savvy you are with your bike bud. If it were me, I'd swap the piston out every 8K to keep it all fresh. But if you rely on your bike and are not a mechanic then I wouldn't bother unless it is exhibiting signs of fatigue.
        3MB is standard across DTR/RE/X. Some early DTR's came with 3BN barrels, slightly bigger bore, shorter stroke.
        • B
          B
          Bentley
          Ok thanks for that I'll order some tonight!
          Haha I'll stay clear of that then. Im not particulary savvy with my bike as I haven't really tinkered with them much but I like to be able to do things myself, I recently put some AC10 tyres on her, so I'm pretty pleased with that although i did puncture a few inner tubes eeeek lmao But it's all sorted now! I don't rely on my bike so I can tinker with her. (And would like too learn etc)
            If you would like to learn then I'd recommend just going to your local scrappy and picking up a spare DT engine and building that. Plenty of them about and you'll learn a lot too!
            B 1 Reply Last reply
              B
              B
              Bentley
              @Calum ok! I know a chap who owns a bike breaker yard. Maybe I'll give him a call, they said they have had Dts in there before. Are you a mechanic? Or did you just teach yourself?
              • B Bentley
                @Bentley Nah I'm not a mechanic bud.
                There isn't much really too these bikes so you pick it up fairly quickly. It won't be long before you're be the one people ask for answers 😄
                Unfortunately, like most, I've learned the hard way. But it's worth every penny as now there is very little I fret in undertaking.
                  B
                  B
                  Bentley
                  @Calum sound words mate. I thought you where lol you've obvisouly done a lot of learning. I bought some of that oil 🙂 she's on the way.
                  If I do decide to inspect the bike at some point I'll post on here with pics for now I'll just ride 😎
                  • B Bentley
                    @Bentley There's always this checklist too refer to bud;
                    https://dt125r.co.uk/topic/275/pre-mot-checks
                      B
                      B
                      Bentley
                      @CYBER-NINJA thanks mate, that'll definitely come in handy.
                      Appreciate the input 👊🏼🍻
                      • ZrakoZ
                        ZrakoZ
                        Zrako
                        Look at this mate
                        Look at this on eBay http://www.ebay.co.uk/itm/371905465746
                        1979 Jawa Mustang 50
                        2003 Gilera DNA 125 R.I.P
                        2015 Keeway TX 125 SM
                        2006 Yamaha DT 125 X
                        MightymanM 1 Reply Last reply
                        • ZrakoZ Zrako
                          Look at this mate
                          @Zrako that was the usual recommended one on the old forum 👍 But tbh, as long as your clutch isn't slipping and your gear changes are Smooth enough, your alright!
                          ZrakoZ 1 Reply Last reply
                          • MightymanM Mightyman
                            ZrakoZ
                            ZrakoZ
                            Zrako
                            @Mightyman yeah . Im used before some 10w40 castrol I had spare in garage but friends told me thats not good use car engine oil in 2 stroke gearboxes as they work different with clutch so thats why Im got this one on the new clutch .got it yeasterday so will put it in as soon as I get my engine back together 👍
                            CalumC ? 2 Replies Last reply
                            • ZrakoZ Zrako
                              @Zrako Austin mini anyone? Shared the same fluid with the engine as the gearbox.
                                @Calum I'm pretty sure the Yamaha WR 125 shares gearbox and engine oil, makes a lot of sense IMO.
                                  @Mightyman My point exactly. I use engine oil and never had a problem.
                                  Obviously as you put more power through the transmission then it's best to have something designed for the application. But 125's ought to be fine.
                                  • ZrakoZ Zrako
                                    A Former User
                                    @Zrako said in Health Check:
                                    its because car oil engine make clutch slip, motorcycle/ATV etc.. engine oil is fine.
                                    CalumC ZrakoZ 2 Replies Last reply
                                    • ? A Former User
                                      @pelplouffe As said that is all I have ever run and my clutch has been fine. Only with the magnetec stuff did the clutch slip.
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        I'd always check the powervalve is working correctly, the condition of the reeds, clean air filter, clean plug, fueling is correct, to start with. Big gains from doing this this if they aren't right.
                                        • ? A Former User
                                          ZrakoZ
                                          ZrakoZ
                                          Zrako
                                          @pelplouffe thats what Im heard and I believe it as my clutch slipped a lot.
