  4. temperature gauge
temperature gauge
11 Posts 8 Posters 3.2k Views
  • A Offline
    A Offline
    anima
    my temp gauge does not work all other parts on clocks work, rev counter speedo etc, i had an overheat last week or so as i was ragging it where would i order the part/parts to get it working?
    • A Offline
      A Offline
      andrewj1680
      Fowlers have a website I use them for all my genuine parts I would start with your cheapest option the temp sender that bolts straight in the top on the cylinder head
      • A anima
        NINJAN Offline
        NINJAN Offline
        @anima See here;
        https://dt125r.co.uk/topic/562/parts-suppliers-database
        • A Offline
          A Offline
          AnthonyPearson
          There is a bolt looking thing with a spade connector, on the head to the front right this is your temperature sender, theres then a wire which connects to this, it may have come off, if not you will have to purchase a new one and there not cheap, £43 if you can find one.
          Blue Yamaha DT 125R 2003
          • A AnthonyPearson
            Louis-DT-WRL Offline
            @AnthonyPearson I used this on my wr200 head, had to drill and tap but works on my gauge, might even fit a 125 head but wrs don't have sensors as standard
            Look at this on eBay http://www.ebay.co.uk/itm/381801768375
            MightymanM A 2 Replies Last reply
            • Louis-DT-WRL Louis-DT-WR
              MightymanM Offline
              MightymanM Offline
              @Louis-James that's a great money saver buying that one! Did it screw flush on the cylinder head? The DT ones only screw in hallway it looks silly!
              • MightymanM Mightyman
                @Mightyman yes because if I remember it's a tapered thread so I tapped it deeper, hope that helps
                • C Offline
                  C Offline
                  castrolsniffer
                  wrote on last edited by castrolsniffer
                  These are not cheap but here u go 😉 http://yambits.co.uk/dt125r-temperature-sender-switch-p-19589.html
                  This is the one with a spade connector but u can save yourself £16 if you are willing to put a bullet connector on your loom http://yambits.co.uk/dt125r-temperature-sender-switch-p-49919.html
                  Bullet is early loom spade is later loom
                  Hope this helps others too 👍
                  • C Offline
                    C Offline
                    castrolsniffer
                    You could just make an adapter with male spade 1 end and female bullet on the other end so u wouldn't have to touch original loom
                      A Offline
                      A Offline
                      AnthonyPearson
                      @Louis-James I was also looking at this in case my one cant be bodged together, this one is for the 50 model but i'm pretty sure that its the same head as it looks like parts are interchangeable on the bikes.
                      http://www.ebay.co.uk/itm/Yamaha-DT-50cc-1995-2008-Temperature-Temp-Sender-Sensor-/361928310266?hash=item54449bbdfa:g:CMIAAOxyoA1RLh5k
                        Better still, grab a thermal coupler.
                        The problem with the temperature sensor is that it measures the temperature of the coolant, not the engine.
                        The engine will go into detonation long before the coolant rises enough to become noticeable.
                        Therefore using a thermal coupler you will notice this spike almost immediately and be able to rectify the situation before it becomes detrimental.
