Zeeltronic
So I'm fitting my 3xp motor into my dtr zeeltronic doesn't do a cdi to run it so wondering if I will just get away with swapping all the electrics over and buying a later servo model loom as my current setup doesn't have the servo unit
@andrewj1680 it's different because my looming, PV servo and stator is the standard Dt125r, but with a wr200 top end and crank. They probably could make one, as mine was the first for my year of Dt125r
The thing is there is a market for the dt unit where as the wr isn't as common so at a guess no benefit to them making a single unit
@andrewj1680 Is there really much gain from a Zeeltronic on the wr, since this was a competition motor.
I don't know to be fair the bike seemed to go well but zeeltronic could possibly take it a step further
@andrewj1680 Are they not able to make you a custom map at all???
@andrewj1680 Not a bad idea, should work fine
