  4. Zeeltronic
Zeeltronic
11 Posts 5 Posters 2.8k Views 1 Watching
    Don't they. What was @Louis-James using?
    A 1 Reply Last reply
      A
      A
      andrewj1680
      @Calum I'm guessing he's using the dt setup
      • A andrewj1680
        Louis-DT-WRL
        Louis-DT-WRL
        @andrewj1680 it's different because my looming, PV servo and stator is the standard Dt125r, but with a wr200 top end and crank. They probably could make one, as mine was the first for my year of Dt125r
        • A
          A
          andrewj1680
          The thing is there is a market for the dt unit where as the wr isn't as common so at a guess no benefit to them making a single unit
          • A andrewj1680
            @andrewj1680 Is there really much gain from a Zeeltronic on the wr, since this was a competition motor.
            DartyD 1 Reply Last reply
            • A
              A
              andrewj1680
              I don't know to be fair the bike seemed to go well but zeeltronic could possibly take it a step further
                wrote on last edited by Darty
                @Calum Probably a fair bit, still a very sedate design
                @andrewj1680 You could probably get a good enough tune using the DT zeel tho,
                The WR could do with a little more ignition advance,
                • A andrewj1680
                  @andrewj1680 Are they not able to make you a custom map at all???
                    A
                    A
                    andrewj1680
                    @Darty I was thinking swap all the electrics for the dt and run a late loom as I can keep the battery too then otherwise it means running the wr200 loom with the power cap
                    • A andrewj1680
                      @andrewj1680 Not a bad idea, should work fine
