  3. Missing oil pump nipple need help!
20 Posts 6 Posters 4.1k Views
  • declanD Offline
    So I've just gone to connect up my oil tank and the nipple on the pump that sends the oil to the intake rubber is missing and I have no idea what to do?
    • G Offline
      G Offline
      gareth_iowc
      A picture would help us see what you are seeing 🙂
      DT125R 2000
      DRZ400 2006
      Golf Mk3 20v Turbo 1996
      • G gareth_iowc
          @declan you see the black rubber nipple behind that there's a little oil pipe and it looks like a nipple was in there but has dropped out at some point maybe I'm mistaken but I'm sure there supposed to be one there
          • A Offline
            A Offline
            andrewj1680
            There is normally 2 one to the inlet and the other you can see in the pic goes to the bottle, looks like you will need a new pump, that or pre mix fuel
            • A andrewj1680
                @declan New oil pump then is all I can say. Never seen thst before.
                declanD 2 Replies Last reply
                  @Calum 😞
                    @Calum do you know what the best pre mix ratio is for the dtr so I can make sure it actually works?
                    • ZrakoZ Offline
                      ZrakoZ Offline
                      Zrako
                      Ehm. I see you only missing the pipe going from pump to intake and slacked cable...
                      1979 Jawa Mustang 50
                      2003 Gilera DNA 125 R.I.P
                      2015 Keeway TX 125 SM
                      2006 Yamaha DT 125 X
                      • G Offline
                        G Offline
                        gareth_iowc
                        How odd. Have you been self mixing up until now then?
                        DT125R 2000
                        DRZ400 2006
                        • G gareth_iowc
                          @gareth_iowc no when I got the bike it was set up but only 2mins after I got it the piston went so it's my first dt so I tore it apart and first start was earlier so I'm not familiar with it so now I'm running pre mix as I can't remember how that pipe had fitted on to there
                          • ZrakoZ Zrako
                            @Zrako cable is no longer slack that was an older pic are you saying there's no nipple for the pipe to slide on to
                            Then?
                            • A Offline
                              A Offline
                              andrewj1680
                              The nipple is there its just the pipe has been cut if you look at it just take that bit of pipe off and replace it that 1 goes to the inlet
                              • A andrewj1680
                                @andrewj1680 The nipple from the Oil Reservoir to the oil pump is missing.
                                  jgr72
                                  What is the inner diameter of the pipe that comes from 2t oil tank -> oil pump?
                                  • J jgr72
                                    @jgr72 around 5mm I think
                                      jgr72
                                      Okey, and is it the same 5mm from pump tu carb?
                                      • J jgr72
                                        @jgr72 Nah, the hose from the oil tank to the oil pump is much larger.
                                        • J jgr72
                                          @jgr72 if I remember I'll look at my other bike it might have the size of pipe printed on it
