  4. Carb warming pipe leaking curse!!!!!
11 Posts 4 Posters 3.1k Views
  • declanD
    So I brought a bike a good few months ago and nothing I done would stop the warming pipes from leaking so I gave up and planning on throwing a dt or 85 engine in it but now I'm having the same problem with my dt any of you came across this and the cap on my expansion tank keeps shooting off!
      @declan Post some pics dude, we're visual peeps in here!!! 😉
      • declanD
        0_1495289548475_IMG_1113.JPG those but mine is looped so it bypasses the carb and they leak where they slide on to the head even with new clips etc
          Head gasket mate. Which would explain why the carb warming pipes won't seal, as they would be the first place to let out the induced pressure.
            @Calum they seal when hot just not at riding temp
            • MightymanM
              Head warped maybe?
              • MightymanM Mightyman
                Head warped maybe?
                @Mightyman I seem to have fixed it just a case of some decent clamps but not ridden it yet so fingers crossed
                MightymanM 1 Reply Last reply
                  @declan If you expansion cap is shooting off, I doubt the underlying issue has been solved. You may be burning coolant in the long term.
                    @Mightyman do I put coolant in the expansion tank or does it go from the rad when cooling?
                    • MightymanM
                      With the bike completely cold, fill up the radiator, then fill up the expansion tank between the min and max marks.
                        @Mightyman thanks!
