  4. Dt125 re not charging battary
22 Posts 6 Posters 7.6k Views
  • R
    R
    reecesloane 2017
    Yes runs perfectly but brand new battary only lasted a couple days I thought it was the battary took it back and got another and that's done the same now all the lights work when running but doesn't charge the battary
    • ZrakoZ
      ZrakoZ
      Zrako
      Did you checked all wires and connectors from generator to rectifier?
      1979 Jawa Mustang 50
      2003 Gilera DNA 125 R.I.P
      2015 Keeway TX 125 SM
      2006 Yamaha DT 125 X
      • R
        R
        reecesloane 2017
        Yes all
        Look pretty good no damage that I can see nothing corroded bikes almost new so abit strange is it possible I'm ising the wrong battary I just got one that had the same dimensions and 12v ect surly it can't be that bad
        MightymanM 1 Reply Last reply
        • R reecesloane 2017
          Yes all
          @reecesloane-2017 generally, as long as it's a 12v battery it shouldn't make any difference so that isn't your issue.
          • R
            R
            reecesloane 2017
            That's what I thought I'm stuck now electrics isn't my thing
            • MightymanM Mightyman
              @Mightyman little bit more to it than that bud. Obviously needs to be rated appropriately otherwise the engine will drain more power from the battery than the battery can supply. But the DT's could probably run off AA batteries lol.
                @Calum aha yeah but generally people look into it much more than need be. "As long as it fits into the battery compartment" is my motto!
                • R
                  R
                  reecesloane 2017
                  So what would be the case now then where and how should I check any help
                  Would be great
                    I would be checking continuity between the genny and the battery terminals. It sounds like the engine is generating power enough to sort itself out, it's just a case of sorting out the charging circuit out.
                    • R
                      R
                      reecesloane 2017
                      It's weird somtimes I think it may be shooting so where it has electric start and also kick start the other day I turned the ignition in and forgot the red on of switch so it was off but when I kicked the bike it was firing envelope a little smoke from the exhaust it wouldn't fully start but was 100% firing then die then I looked at the switch seen it was of turned it on and it started right up could this be an issue or is this normal thanks
                        I guess that could happen on a warm bike.
                        Before doing any more diagnostics regarding the battery/charging, you need a battery in good working order. You might be able to salve the current one, by putting it on a charger.
                        • R
                          R
                          reecesloane 2017
                          The battary is brand new just went flat I'll charge it up
