  4. Took head off after breakdown
33 Posts 7 Posters 10.0k Views
  • ZrakoZ
    ZrakoZ
    Zrako
    wrote on last edited by Zrako
    Well , finally opened the engine , this piston did 400 miles , find out that 300ml trans oil left , bit in coolant and lot in crank case. Sparkplug was badly fouled , similar to the piston on the pic . I was probably burning it as well but didnt smell or didnt seen any bad smoke... Trying to figure out what actually happened.
    Aaand this 😓
    1979 Jawa Mustang 50
    2003 Gilera DNA 125 R.I.P
    2015 Keeway TX 125 SM
    2006 Yamaha DT 125 X
    • ZrakoZ
      ZrakoZ
      Zrako
      Any idea what I did wrong?
        Did you replace the crankshaft seal?
        If so did you have it on the right way round?
        ZrakoZ 1 Reply Last reply
        • ZrakoZ
          ZrakoZ
          Zrako
          Which seal is it?
          • L
            L
            louis
            The piston looks like you went to lean.
            Google "lean piston" and you see many like them.
              ZrakoZ
              ZrakoZ
              Zrako
              @Calum googled it , no I didnt. Used the old ones.
              • ZrakoZ Zrako
                @Zrako It looks incredibly oily.
                I thought you said you rebuilt the engine sorry?
                It's hard to say what the problem is, although if it's lost gearbox oil, and oil was in the crank case and the piston is filthy, then it could have been the crank seal.
                  ZrakoZ
                  ZrakoZ
                  Zrako
                  @Calum yes I did rebuilt it like 3 months ago I think. Gonna get the seals and replace them soon . I have a spare mitaka piston , but both looks slightly different than the one before. Will post a pics tomorrow...
                  • ZrakoZ Zrako
                    @Zrako So what did you rebuild exactly? If you used old components then that might be the problem. I think they're only a couple of quid and for the sake of them I'd just replace them.
                    • ZrakoZ
                      ZrakoZ
                      Zrako
                      @Calum My bottom end bearing gone before so I got the new conrod and piston , got the crank rebuilt , used new gaskets and fasteners, new clutch plates and springs,installed kickstart ,new oil and waterless coolant... same big one pipe as I had before but in good condition... Thats it basically.
                      • ZrakoZ Zrako
                        @Zrako what! And you didn't replace the crank seals? For the few quid and two seconds it takes?
                        If the big end bearong went then it's likely that it took the seals with it. I would replace both of, which means splitting the cases unfortunately.
                          ZrakoZ
                          ZrakoZ
                          Zrako
                          @Calum well ,Im failed again then... never did it before but will remeber that for future. Ordered them now. Thanks for help
                          • ZrakoZ Zrako
                            @Zrako Let's hope this was the failure point.
                              ZrakoZ
                              ZrakoZ
                              Zrako
                              @Calum thinking about build it up again and give it to someone to check and tune it properly as Im lost confidence haha .
                              • ZrakoZ Zrako
                                @Zrako Not really mate. It's so simple and we are here to help.
                                Literally it's the crank seals. Yoy gotta imagine that when the bearings went they would have gone for the softest part of the engine, whih is the seals.
                                  ZrakoZ
                                  ZrakoZ
                                  Zrako
                                  @Calum yeah , didnt thought about it as I think I checked them , silly mistake. Do you think I will need a new head gasket ? Im did the light skim as you made the tutorial for it , dont know how to identify if the head gasket is bad or reuseable...
                                  • ZrakoZ Zrako
                                    @Zrako Head Gaskets are not reusable.
                                    My advice, don't take the head off, but I'm guessing it's too late for that now.
                                    Athena head gasket is only a tenner.
                                    • ZrakoZ
                                      ZrakoZ
                                      Zrako
                                      Well , here we go again . 2nd rebuild . Now with new crank bearings and seals 🙄 , new piston and rings , new - used clutch , removed kickstart and got new used stay for the sprag clutch and installed starter motor, fresh gear oil.
                                      https://youtu.be/b2MZ359Ag3g
                                      Here is what it sounds like . First start was surprisingly smooth ,was idling bit higher so turned it down and bled autolube . Feel strange as it was maybe too good to be true lol .
                                      Let me know what you think about the sound. Havent jump on it yet btw.
                                      • ZrakoZ Zrako
                                        @Zrako Sounds like a 4 stroke with the airbox lid off. LOL
                                        Great job tho!!! 👍
                                        • ZrakoZ
                                          ZrakoZ
                                          Zrako
                                          Well , brand new iridium br9eix after like 30 minutes idling. First 5 minutes was bleeding oil pump. Doesnt smoke too much . 🤕
